09-27-2013 08:33 AM - edited 03-16-2019 07:35 PM
We use CUCM on our main sites. We've started to deploy CME on field offices.
Is it possible to activate extension mobility between CUCM and CME ?
ie: being able to log on a CME managed phone with a CUCM account and from CME to CUCM ?
Solved! Go to Solution.
09-27-2013 08:44 AM
No, you can only do that between CUCM clusters, if both support EMCC.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
09-27-2013 08:44 AM
java
09-30-2013 02:01 AM
Thanks for your answer, I was hopping to have someone with a by-pass solution...
NH
