09-09-2016 04:58 AM - edited 03-18-2019 12:06 PM
Hello we are experiencing some unusual behavior with EM on CUCM 10.5. We have multiple users that only have an EM device profile that they use to log in and out of phones with. When they are not logged into a phone it follows the call forward unregistered in the line settings of the DP. However if the EM DP line has Call Forward All setup to go to an external number and it is not registered when the EM line is called we get a fast busy. When registered it goes to the external number. If it has an internal extension programmed it will ring the extension when unregistered.
Why does it not follow the CFA to an external number when not registered?
09-09-2016 08:05 AM
Hi Ed,
Have you checked/verified the Call Forward Unregistered CSS?
Cheers!
Rob
09-09-2016 08:06 AM
Is the behavior different if you call the extension the is logged out internally versus externally? How are calls routed to the PSTN? Is there a local route group? If so, you might not have an LRG set on the device pool of the gateway where the call enters the network.
