Extension Mobility - CME
twfredericks
Beginner
Beginner
Hello Guru's -
I recently impletemented a medium sized CUCME 9.1 solution in which all users (about 75) are using extension mobility because they change desks often based on the job function they are performing.
The site admin requested that the users be able to change their extension mobility password that is used to log into the phone.
My question is, is there a way for a user to change that password through CMUSER webpage like in full blown CUCM? If so, is there any specific configruation required to enable this functionalty? I have scoured the web and support communities for some direction but haven't found anything as of yet.
I greatly appreciate your time and help!
Tom
dwhitefo
I believe the only thing that an extension mobility user can change through the web interface is the speed dials.  It do not believe there is a way to change the user password through that interface.
Recognize Your Peers
