04-27-2013 06:22 AM - edited 03-16-2019 05:02 PM
I upgrade my set 6921 to firmware 9.3.3.2 after that EM service disappear I already checked the extension mobility on device page it's checked but in phone it's disappear.
Solved! Go to Solution.
04-28-2013 06:02 AM
Ahmed,
Like I said earlier this is a firmware issue...I suggest you downgrade or upgrade the firmware
Please rate all useful posts
"opportunity is a haughty goddess who waste no time with those who are unprepared"
04-28-2013 06:26 AM
The firmware which is being used on IP phones is the latest one . Also, I referred Release notes for 6921 with 9.3(3) firmware which says
Before deploying the 9.3(3) firmware, the Cisco Unified Communications Manager must be updated to the latest device pack.
So, the only option left is to degrade.
regds,
aman
04-27-2013 06:27 AM
Hi Ahmed,
Can u check whether EM services are subscribed/unsubscribed for the phone in related links?
regds,
aman
04-27-2013 07:01 AM
Thanks for fast reply
EM service is enterprises subscription
04-27-2013 07:09 AM
Hi Ahmed,
What i was refering to this :
Are u facing the problem in 6921 only or other phones as well?
What is CUCM version?
regds,
aman
04-28-2013 01:40 AM
Aman,
When you use enterprise subscription, you cant subscribe/unsubscribe to that service...You can configure EM as enterprise subscription or as "manual subscription"...
Ahmed,
This is most likely a bug...A while I go I ran into a bug on tis phones where users couldnt log out of EM..In other words the EM service hung on the phones..
I suggest you either upgrade your firmware or downgrade it
04-28-2013 02:19 AM
Hi ,
thanks for correcting me.
regds,
aman
04-28-2013 02:47 AM
Thx for ur cooperation
I will try n let u know
Thx
04-28-2013 03:03 AM
Hi Ahmed,
I think u are running cmterm-69xx-sccp.9-3-3-2-up.cop.sgn which is the latest available.
I was referring Release notes of the above firmware, which says that device pack needs to be applied to Call Manager before we deploy this firmware.
Did u apply Device Pack?
regds,
aman
04-28-2013 03:15 AM
Hi Ahmed,
Please let us know Call Manager version u are using.
regds,
aman
04-28-2013 03:55 AM
I am using version 8.6.2.20000-2
04-28-2013 03:57 AM
How I apply device pack
04-28-2013 04:03 AM
Hi Ahmed,
U need to download Device Pack from below URL and size is 640.16MB
cmterm-devicepack8.6.2.23071-1.cop.sgn
Just try uploading on one of the first server , restart TFTP service.If it is successful, then, we can upload on other servers in same cluster.
Just refer this sheet of Device Packs compatibility.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/compat/devpack_comp_mtx.html
How to upload
1. Using your web browser, log in to the Cisco Unified Communications
Operating System Administration web page.
2. From the Software Upgrades menu, select Install/Upgrade.
3. Fill in the appropriate values in the Software Location section and click
Next.
4. In the Available Software drop-down box, select the device package file
and click Next.
5. Verify that the MD5 has the correct value. Click Next.
6. In the Warning box, verify that you selected the correct firmware and
then click Install.
7. Check that you received a Success message.
8. Stop and restart the TFTP server.
9. Reset the affected devices to upgrade the devices to the new load.
regds,
aman
04-28-2013 04:43 AM
Is upgrading device pack will affect my license or needing a license or not?
What u mean by install on one of my first server ? I have one pub and two sub which one ?
Thx
04-28-2013 05:25 AM
Hi Ahmed,
Nothing to do with licenses.
U need to load Device pack on all the servers in a cluster.You can upload pack on server where the phones are regsitered just to cross-check whether problem is resolved or not.
regds,
aman
04-28-2013 05:36 AM
Ahmed,
You dont need to install a device pack. A device pack is a collection of firmware for severak devices. If all you want to do is install firmware for your 6921..then it is what you have done. If your phoned have upgraded tot he new firware then you have done the correct thing...I belive that you installed the cop file on all your servers and re-started your tftp service.
Dont worry about the device pack you dont need it
