03-28-2018 07:18 AM - edited 03-17-2019 12:30 PM
We have a single cluster hosting multiple sites with EM enabled for all users. All external calls including emergency calls are routed out a SIP trunk hosted in a central datacenter. There are no local gateways at any site.
As a result when EM users travel between different sites and dial emergency numbers it causes a problem as their calling number is from their home site.
I can't really see a solution to this, has anybody any experience of this issue?
Solved! Go to Solution.
03-31-2018 01:05 PM
03-28-2018 07:25 AM
You could try device mobility to block those calls, or this would be more of a user education scenario and you'd need to explain them to not use 911 or call from other local device
03-28-2018 10:18 AM
You need CER or RedSky to route 911 calls based on switchport or IP subnet instead.
03-31-2018 01:05 PM
