12-21-2017 02:40 PM - edited 03-17-2019 11:49 AM
CUCM CUC IMP 11.5 9971s, 8851s, 7841s, Dx80s, Sx10-20s. We are looking at implementing EM and I was wondering if there are bugs etc to consider when doing this ? Like, EM does not work well when you have Jabber, all device types everywhere for us or remote users via expressways or telepresence or ? If anyone might share concerns. I'm hoping it will work fine for everything "out of the box ". Thanks,
Solved! Go to Solution.
12-22-2017 06:39 AM
12-21-2017 02:59 PM
*Ideally* everything should work out of the box, the EM configuration steps have an interactions/restrictions section which you should review.
Aside from that, yes, there are bugs that can affect EM, but you'd need to review the ones that affect your CUCM release and determine if you might hit one, and need to upgrade CUCM or the phones FW.
12-22-2017 06:39 AM
