Community Helping Community
1277
Extension Mobility - Ip Phone 9971
All,
Someone has news of failure with the Extension Mobility for 9971 phone?
I can easily set up multiple 7965 phones, but not for the 9971 phones. Is there any difference or specific details?
Luciane de Medeiros
1 ACCEPTED SOLUTION
Hall of Fame Master
is the service subscribed on to the phone?  In CUCM go to device --> phone, locate this phone and in upper right corner select Subscribe/Unsubscribe services from related links, make sure the service is subscribed.
HTH,
Chris
7 REPLIES 7
Collaborator
Hello only the 9971 has this problem?
Whats is the CUCM version?
Firmwae version of the 9971?
Hall of Fame Master
What is the issue exactly?  You cannot login with EM onto the phone? You cannot create UDP? What error are you receiving?
Chris
Highlighted
Leonardo e Chris,
When I press the button "Applications" in the model 9971 does not appear the option of Extension Mobility.
I'll check the version of Communications Manager and phone firmware.
Thank you!When I press the button "Applications" in the model 9971 does not appear the option of Extension Mobility.
Thank you!
Luciane
Leonardo e Chris,
Thank you! When I press the button "Applications" in the model 9971 does not appear the option of Extension Mobility.
Thank you!
Luciane
Hall of Fame Master
HTH,
Chris
Ok, Chris.
I'll check.
Thank you! Ok, I'll check.
Thank you!
Chris,
Great! It's working!
Thanks!
Luciane
Content for Community-Ad
FusionCharts will render here
