02-09-2017 01:50 PM - edited 03-17-2019 09:28 AM
Is EM supported while connected via the anyconnect VPN. I have EM working fine on phones inside the network, but when testing on a phone outside the network connected via the anyconnect VPN I get "Host not found".
Thanks.
02-09-2017 04:05 PM
Can you use the corporate directory or other IP Phone services?
02-10-2017 01:21 PM
Yes, I am able to use the Corp Directory and IPMA services.
02-10-2017 02:02 PM
I figured it out. Port on ASA was being blocked. Got it working now.
09-04-2018 10:22 AM
Hi Can you let me know which port specifically?
Doing POC and hitting the same issue.
Nasir
09-04-2018 10:28 AM
Hi Nasir,
Check under “Ip phone services” the extension mobility service url and make sure that port is opened on your firewall.
Also check if Certificate is correctly installed on your IP phone.
Carlo
09-04-2018 10:29 AM
09-04-2018 12:58 PM
For my setup the CUCM authenticates the user properly shows "login successful" message. and stuck on Phone registration.
I think the next TFTP pull is not working.
note: EM inside LAN setup is working fine. I am able to login with same username and password. The UDP and user association is proper.
