11-12-2012 01:18 PM - last edited on 03-25-2019 08:18 PM by ciscomoderator
I tried searching the forum, but did not find my answer. Is there a way to retrieve past records to find where a user logged in to EM through a number of devices and exactly what time logged off from all those devices?
11-12-2012 04:49 PM
You would need to enable EM traces and parse thru them to get that kind of information.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
11-13-2012 08:13 AM
Thanks Jaime! Where would I go to enable EM traces? And by parse through them, can I do it through CAR or RTMT?
