Extension Mobility weird - successful but profile not applied
Novriadi .
Hi Folks,
I have a weird case with extension mobility feature.
I'm using CM 8.5.1.10000-26 with several IP Phone series like 6921, 7945 and 9971.
I've check the EM configuration on call manager and all configuration should have been configured properly.
The case is :
When I log in to EM service in one of IP Phone type, log in status is successful but my profile doesn't apply to the phone. (this occur on all IP Phonein Cluster)
I check on EM status in Call Manager > Device Phone , the status log in is successful with profile applied to the phone.
Troubleshoot :
I've done with restart CM cluster, deleted all EM configuration and configure EM from the scratch.
but the status still same with EM login successful with failto applythe profile to the phone.
I'm appreciate with your experience & suggesstion.
Novriadi
6 Replies 6
michelnasr
Do you have your end users controlling each his profile ?
Hi Michel
I have end user controlling the profile.
currently the Call Manager sync to two LDAP server..when I check to Subscriber server, on User Management > End User > and click to one account of from one of LDAP server, I found the error like this (see attachment).
I suspect we have a problem with dual LDAP source for End User, then impacted to Extension Mobility feature when I use user ID from the LDAP.
have you experience with this ?
To rest your case, stop LDAP, create 1 user, make sure you associate a profile (controlled) to this user and log in.
Let me know the result
Hi Michel,
I try to delete one of my LDAP A connection, user status (LDAP A) inactive, then i try to login to EM using User ID from LDAP B, login susccesful and profile applied to the phone.
so, what the root cause ? Is CM doesn't supported dual LDAP connection ?
connection to two LDAP is mandatory in my environment because we need an user infromation that not included in LDAP A (Main LDAP).
Novri
What happens if u do it in reverse? Delete LDAP B, and log in from LDAP A user !
What are the LDAP types u're using ?
Hi Michel
Sorry i'm late to answer.
I want to clarify that my problem was solved
the root cause is Call Manager database out of sync between Publisher and several Subsriber server.
now I can use 2 LDAP (AD type) for user database & EM feature run normally.
Thanks for response and your help.
Novri
