04-03-2019 02:36 AM - edited 04-03-2019 02:37 AM
I am working on CUCM 10.5 version where facing issue with the Extension Mobility feature...unable to see Extension mobility service in Device of Device profile Subscribe/Unsubscribe
1. "Cisco Extension Mobility" service is Activated in CUCM serviceability page
2. created "IP Phone Services Configuration " for Extension Mobility with the URL "http://192.168.18.55:8080/emapp/EMAppServlet?device=#DEVICENAME#"
3. Then also i am unable to see Extension mobility Subscribe/Unsubscribe Services
attached are the required snap shot ..I also done CUCM restart 2 times .
I configured CIPC SIP Device
04-03-2019 02:52 AM
Have you assinged the corresponding Service URL Button on the phone (CIPC) that you want to enable Extension Mobility?
04-03-2019 02:54 AM
You may follow the guidelines described below:
https://www.youtube.com/watch?v=8XbrG4jXxPo
George
04-03-2019 04:39 AM
When you configured Extension Mobility, did you check the box for "Enterprise Subscription"? If so, then the behavior you are seeing (not possible to manually subscribe) is normal behavior. With Enterprise Subscription, every phone (current and future) is already subscribed and every device profile (current and future) is already subscribed.
You can see if your EM service is an Enterprise Subscription if you go to Device > Device Settings > IP Phone Service and do a Find to list all of the services. One of the columns that shows up is whether the service is Enterprise.
And if you are wondering why that checkbox does not appear on the EM Service configuration page itself, that is also normal. The Enterprise Subscription checkbox is only available at the time of initial creation/configuration. Once the service is saved (whether the service is Enterprise or not) the checkbox no longer appears.
Maren
