01-15-2021 01:42 AM
I have external call transfer restrictons in place on our Call Manager 10.5 system.
I wish to remove the restrictions so that I can call a DDI from an extenal number, which then diverts to a mobile.
I have set the feature service offnet-to-offnet transfers to false, set on-net on service call classifcations and also set route patterns and the trunk.to off-net.
Call forwarding is set correctly with regards to call search space.
DDI will divert to the mobile from inernal numbers but not from an external call due to the existing call restrictions in place that I cant seem to undo.
Nothing seems to work.
I basically done the reserve for setting up call restrictions; following the cisco white paper.
What am I missing ?
All help appreciated.
01-15-2021 02:26 AM
DDI will divert to the mobile from internal numbers but not from an external call:- - Most ISP's drop the call if ANI is other than the DID range. Some ISP translate it to the DID pilot number.They do this for billing purpose. For the scenario which doesn't work, check the ANI send to ISP.
01-15-2021 02:49 AM
Thanks Nithin,
I did consider this but ruled it out.
What is the best way to check the ANI sent to ISP ?
01-15-2021 04:30 AM
Debug in the gateway would be the way to go. If it's a TDM connection to PSTN with ISDN use debug isdn q931 and if it's a ITSP connection with SIP trunk use debug ccsip messages.
01-15-2021 08:29 AM
Thanks Roger.
We have a SIP trunk so will try the debug commands you have suggested.
01-15-2021 04:40 AM
If you have SIP connectivity with the provider, then try on your CUBE the command "debug ccsip messages" and check what is sent to the provider. Most of the times the Provider blocks the call if the ANI is not within the specified DID range.
I hope this helps,
George
01-15-2021 08:27 AM
Thanks George, will try the debugs. Waiting for provider to confirm if they are indeed dropping calls outside our DDI range.
02-09-2021 05:56 AM
Hi All,
Still trying to resolve this.
Our ISP has got back to me and have confirm they are not dropping the calls but our device is ie The phone with the divert on.
The error is : SIP/2.0 480 Temporarily Not Available.
What is the best way to determine what is causing this error ? Looks like a config issue on our Call Manager but I'm just not seeing it.
I've check route patterns, calling space, trunk call classifications and everything appears to be fine.
Appreciate any advice as always.
02-09-2021 08:02 AM
To provide more informations you need to share the debugs.
02-09-2021 09:10 AM
Thanks Nithin,
Manage to sort this.
I needed to add the local route group to the device pool associated with my sip trunks.
Not sure why as all outbound calls route fine without me needed to add the local route group to the device pool.
Thank you all for your responses.
02-09-2021 10:55 AM
Because you configured LRG. If you need to learn more about LRG go through below document.
03-03-2021 08:20 AM
Sorry Nithin, just seen this.....
Will read tead through - thank you very much.........
Paul
01-15-2021 05:08 AM
Use commands @Roger & @George Sotiropoulos mentioned.
