53
Highlighted
Beginner
External Caller able to dial 9,911 from Unity
I have restriction tables setup to not allow a 9 to be dialed from Unity, Auto Attendant or otherwise but over the weekend we had a call to 911 from one of the campuses and looking back through CAR reporting I see where the call originated from one of the Unity voicemail ports.  I've also tested myself to see if it will allow me to dial out from the AA and it is not.
I appears I'm missing something, any ideas?
Everyone's tags (1)
1 REPLY 1
Highlighted
Rising star
Even if Unity connection
Even if Unity connection allowed 911 or 9911 to be dialed from an AA, the CSS of the VM ports on CUCM would have to allow the call in order for it to reach the PSTN.
I would suggest looking through the CSS assigned to the Unity Connection voice mail ports on CUCM, and ensure 911 or 9911 is not able to be dialed.
If you are unsure about whether the CSS assigned to the ports will allow emergency calling, you can use DNA on CUCM to find out.
1. Go to CUCM IP address /dna in your web browser. Example: "https://10.1.1.1/dna"
2. Navigate to Analysis > Analyzer
3. Enter 911 or 9911 into the "Dialed Digits" section
4. Set the "Calling Search Space" to the same CSS that is configured on your voice mail ports.
5. Click "Do Analysis" and see if the pattern is blocked or not.
If DNA does not load, ensure the service is activated:
1. Go to "Cisco Unified Communications Manager Serviceability".
2. Navigate to "Tools > Feature Services"
3. Select the IP address of the CUCM publisher and then click "Go"
4. Start the "Cisco Dialed Number Analyzer Server" and "Dialed Number Analyzer" services.
