06-22-2022 08:12 PM
I have fax machines setup on a VG310 and they are able to fax internally between each other with no issues. When I try to send a fax externally I get a "Line Busy" error on the fax machine. Inbound faxes don't seem to come in. I cannot seem to find any reason that these should not work.
I also have analog phones configured on this same VG310 and they have no issues calling out or receiving calls.
Solved! Go to Solution.
07-04-2022 07:37 AM
Looks like I am having a communication error between one of my CUCM servers and the gateway. I ended up switching the server my Trunk was communicating with and it worked just fine.
06-22-2022 11:50 PM
Make sure that you use g711 as the codec for the call out via your voice gateway for the out/in -bound calls from the VG port. What type of connection do you use for the connectivity with PSTN? Can you please share a debug of the failed calls?
06-23-2022 06:27 AM
I have g711 setup as the codec for this. My PSTN is connected to a T1 PRI. When I did Debug CCSIP Calls and Debug isdnq931 for outbound calls I got nothing in my logs when I did an outbound call.
06-23-2022 06:36 AM
If you get nothing it would mean that the call doesn’t hit the gateway. For this you should look at call routing in CM. Start with doing a DNA and check calls from this device to the number that you’re trying to fax to.
06-23-2022 12:02 AM
06-23-2022 06:22 AM
I currently do not have fax relay turned on for my dial-peers.
07-04-2022 07:37 AM
