Showing results forĀ
Search instead forĀ
Did you mean:Ā
External Incoming Calls problem.
Amjad Hashim
Hello everybody,
One of our voice gateway router is  having problem in it. it is not working well and can't receive call coming through. I think call is hitting our router and our router is dropping it.
It is a ISDN BRI router with 2 BRI lines coming in. In CCM manager it is added as MGCP gateway but it has its own dial peer configurations as well. i have checked and it is not receiving any config from CCM manager.
here is the debug for isdn q931.
ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
        Bearer Capability i = 0x8090A3
                Standard = CCITT
                Transfer Capability = Speech
                Transfer Mode = Circuit
                Transfer Rate = 64 kbit/s
        Channel ID i = 0x89
                Exclusive, B1
        Called Party Number i = 0x81, '510859'
                Plan:ISDN, Type:Unknown
16:51:19: ISDN BR0/1/1 Q931: RX <- SETUP pd = 8  callref = 0x01
        Sending Complete
                Standard = CCITT
        Channel ID i = 0x89
                Exclusive, B1
16:51:23: ISDN BR0/1/1 Q931: RX <- DISCONNECT pd = 8  callref = 0x01
        Cause i = 0x82E6 - Recovery on timer expiry
16:51:23: ISDN BR0/1/1 Q931: TX -> RELEASE_COMP pd = 8  callref = 0x81
        Cause i = 0x80D1 - Invalid call reference value
I am also receiving a warning message on voice card which is
voice-card 0
! Warning! DSPs 1 in slot 0 are using non-default firmware from device flash:
! This is not recommended, the IOS default version is 24.3.0
dsp services dspfarm
Also see the following output of show voice dsp detailed command
edsp 0001 01 g729r8 p  0.1 IDLE  50/0/1.1
edsp 0002 01 g729r8 p  0.1 IDLE  50/0/2.1
edsp 0003 01 g729r8 p  0.1 IDLE  50/0/3.1
edsp 0004 01 g729r8 p  0.1 IDLE  50/0/4.1
edsp 0005 01 g729r8 p  0.1 IDLE  50/0/5.1
edsp 0006 01 g729r8 p  0.1 IDLE  50/0/6.1
edsp 0007 01 g729r8 p  0.1 IDLE  50/0/7.1
edsp 0008 01 g729r8 p  0.1 IDLE  50/0/8.1
edsp 0009 01 g729r8 p  0.1 IDLE  50/0/9.1
edsp 0010 01 g729r8 p  0.1 IDLE  50/0/10.1
edsp 0011 01 g729r8 p  0.1 IDLE  50/0/11.1
edsp 0012 01 g729r8 p  0.1 IDLE  50/0/12.1
edsp 0013 01 g729r8 p  0.1 IDLE  50/0/13.1
edsp 0014 01 g729r8 p  0.1 IDLE  50/0/14.1
edsp 0015 01 g729r8 p  0.1 IDLE  50/0/15.1
edsp 0016 01 g729r8 p  0.1 IDLE  50/0/16.1
edsp 0017 01 g729r8 p  0.1 IDLE  50/0/17.1
edsp 0018 01 g729r8 p  0.1 IDLE  50/0/18.1
edsp 0019 01 g729r8 p  0.1 IDLE  50/0/19.1
edsp 0020 01 g729r8 p  0.1 IDLE  50/0/20.1
----------------------------FLEX VOICE CARD 0 ------------------------------
                           *DSP VOICE CHANNELS*
CURR STATE : (busy)inuse (b-out)busy out (bpend)busyout pending
LEGEND     : (bad)bad    (shut)shutdown  (dpend)download pending
DSP   DSP                 DSPWARE CURR  BOOT                         PAK   TX/RX
TYPE  NUM CH CODEC        VERSION STATE STATE   RST AI VOICEPORT TS ABRT PACK COUNT
C5510 001 01 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 02 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 03 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 04 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 05 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 06 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 07 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 001 08 None           0.0.0 bad   idle      0  0                 0          0/0
C5510 005 01 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 02 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 03 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 04 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 05 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 06 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 07 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 08 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 09 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 10 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 11 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 12 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 13 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 14 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 15 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 005 16 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 01 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 02 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 03 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 04 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 05 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 06 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 07 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 08 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 09 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 10 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 11 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 12 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 13 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 14 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 15 None          24.3.0 idle  idle      0  0                 0          0/0
C5510 006 16 None          24.3.0 idle  idle      0  0                 0          0/0
                           *DSP SIGNALING CHANNELS*
------------------------END OF FLEX VOICE CARD 0 ----------------------------
I hope to receive some positive comments from you people. I have checked a few documents and they says the default dspware for 12.24t IOS is 24.3.0 which is shown in the output with other DSPs except dsp 1 and if i am not wrong it is embedded in IOS rather then standalone because i can't see any file in flash which could be DSPware. Any help will be much appriciated.
2 Accepted Solutions
Payal Bhaduri
The reason you are getting the dsp error message is because your DSP 1 in slot 0 is bad and it needs to be replaced.
Seems like the PVDM-8 is faulty.
7 Replies 7
Payal Bhaduri
You could use the  "OPEN a TAC" button to have it looked at. Maybe process an RMA if needed.
Hello Payal,
I am not good with Voice but i think ISDN BRI cards don't have any DSP on board, so it means there will be something else that need doing to resolv it or replacing BRI cards will do it?
Do u think that call receiving problem could be because of this DSP issue?
Cheers!
Can you please send me the show tech?
Please find attached tech information.
Amjad
I have replaced my PVDM-8 slot on router and it started working again. Lots of thanks to everybody who was trying to help resolve the issue.
Cheers!
