09-13-2012 12:44 AM - edited 03-16-2019 01:10 PM
Guys,
Im facing an issue...I've configured correctly, but cant configure an external (secondary) number for 9971.
Any help?
Edson Vuma
09-13-2012 02:05 AM
What exactly are you trying to do? Are you referring to the external mask, or are you referring to the ability to have a second line on the 9971?
You said you've configured correctly, but can't configure.
09-14-2012 12:07 AM
Andrew
Is a second line on the 9971.
For examble...on SCCP phones, to create a secondary number, I made like this:
ephone-dn 11 dual-line
number 12 secondary 2xxxxxxx
label phoneLabel
name phoneName
I would like to add a "secondary number" to the 9971, which uses SIP.
Edson Vuma
09-16-2012 11:36 PM
Any help?
Edson Vuma
09-17-2012 06:24 AM
What version of UCM are you using?
09-17-2012 06:43 AM
He is using CME based on the snippet of config posted.
Edson,
Use translation profiles to mask caller ID appropriately.
Chris
09-17-2012 10:43 PM
Chris
Would you be more specific.
Sorry
Im not familiar with translation profiles.
Thanks for your help
Edson Vuma
09-18-2012 06:59 AM
Hi Edson,
There's no such thing as secondary number for the voice register dn's, unfortunately, seems that the option is just for SCCP phones, what you can do, is to create translation-rules to macth the DID with the extension number, if that is the case:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_tech_note09186a0080325e8e.shtml
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00803f818a.shtml
Jorge Armijo
11-13-2012 12:17 AM
This question is done:
Just add two dn and on one of them, add this second number.
voice register pool 1
busy-trigger-per-button 10
id mac
type 9971
number 1 dn 1
number 2 dn 2
dtmf-relay rtp-nte
codec g711ulaw
voice register dn 1
number 01 ← Internal number
allow watch
voice register dn 2
number 21359045 ← External number, on this case I used a example number with the prefix 21 (local prefix in Maputo-Mozambique).
create profile.
And its now working.
Edson Vuma
