02-23-2011 03:35 AM - edited 03-16-2019 03:36 AM
Hi all
I'm running CM6.1
If I set the external phone mask on a line it shows up on the black strip of the phone screen. Is there a was to set the external phone mask but NOT have it show up on the phone? I just want the extension number on the black strip.
Michael
02-23-2011 04:08 AM
If all the phones have the same external mask you can set it on the route list calling party transformations. If you've got several ranges, then you should just configure the transformation on the H.323 gateway.
Please rate if this helps.
Michael
02-23-2011 05:26 AM
only a handfull of users need the external mask out of >100 so I can't do it the easy way
02-23-2011 06:24 AM
Unfortunately you cannot hide it on the phone once you configure it at the device level.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
