12-22-2015 11:37 AM - edited 03-17-2019 05:18 AM
Is there a Service or Enterprise parameter that will override the external phone number mask for a DN in CM 10.5? I have the external number mask set as the main number for some extensions but the caller ID showing on the called phones outside of our network is showing the DID.
Thanks in advance.
Replies rated
12-22-2015 11:44 AM
There is a few places where this can happen. Within CUCM you can have Calling party transformations at the Route List level or even at a Translation pattern level will override your external phone number mask.
If you are using a CUBE, translation rules would override this as well.
I recommend that you try using the dialed number analyzer within CUCM to truly understand what your call is doing, or you could go straight to traces if you feel comfortable.
FG
12-22-2015 12:05 PM
Route pattern mask setting will override the DN level mask setting applied.
refer the SRND section 'Route Pattern Configuration' for more on the same.
Calling Party Transformations
Use Calling Party's External Phone Number Mask |
Check the check box if you want the full, external phone number to be used for calling line identification (CLID) on outgoing calls. You may also configure an External Phone Number Mask on all phone devices. Note |
regards,
-Do rate helpful posts
