Extracting Data from Call Manager
fwhodits3
Is there a way to export or run a query against the Call Manager DB to pull the Owner User ID field and the Line One association. I do not know what DB Call Manger uses or what table this information would be in. I am new to Cisco Call Manager and we need to make sure the phone numbers in our AD accounts match what we have in Call Manager.
Thank you.
Frank
Jaime Valencia
The document you would need to refer to is the CUCM data dictionary which has all the CUCM DB tables and fields in each table. Then you run the command "run sql < your SQL query >" and you'll get the output.
java
if this helps, please rate
Chris Deren
Another option is just to do phone export and look for that data in the CSV file.
