FAC code in CDR
john katsavras
Hi there
Just trying to get the FAC code to show in the CDR.
We have set Clusterwide Parameter: "Display FAC in CDR" to true (didnt restart any service as manual says you dont neet to) but authorizationCodeValue filed in cdr still shows up with value "null"
We are running CM ver 8.5.1
Alexis
http://www.netpacket.co.uk/ http://www.blog.netpacket.co.uk/
2 Accepted Solutions
Rob Huffman
Hi Alexis,
I believe this is actually working as designed
Forced Authorization Code (FAC)
When the FAC feature gets invoked, the system writes the authorization  description and level into the CDR. For security reasons, the actual  authorization code does not get written to the CDR.
The authCodeDescription field contains the description of the authorization code.
The authorizationLevel field contains the level of authorization that is associated with the authorization code.
FAC CDR Example
45000 calls 9728134987; the system prompts the user for an authorization  code and enters 12345. FAC code 12345 gets configured as level 1 and  name Legal1. The caller answers the call and talks for 2 minutes.
Field Names
Values
globalCallID_callId
100
origLegCallIdentifier
16777123
destLegCallIdentifier
16777124
callingPartyNumber
45000
origCalledPartyNumber
9728134987
finalCalledPartyNumber
9728134987
lastRedirectDn
9728134987
origCause_Value
dest_CauseValue
16
authCodeDescription
Legal1
authorizationLevel
duration
120
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/service/8_5_1/cdrdef/cdrex.html#wpmkr1255492
And from the SRND;
Forced Account Codes (FAC)
• The Forced Account Codes (FAC) checkbox is used to restrict the outgoing calls when using a
particular route pattern. If you enable FAC through route patterns, users must enter an authorization
code to reach the intended recipient of the call.
• When a user dials a number that is routed through a FAC-enabled route pattern, the system plays a
tone that prompts for the authorization code. To complete the call, the user authorization code must
meet or exceed the level of authorization that is specified to route the dialed number.
Only the authorization name appears in the call detail records (CDR); the authorization code does
not appear in the CDR.
• The FAC feature is not available if the "Allow overlap sending" checkbox is enabled.
https://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/dialplan.pdf
Cheers!
Rob
"And if I should fall behind
Wait for me" - Springsteen
Just to give an update on this FAC code started been displayed in the CDR a day later
alexis
Rob Huffman
Hi Alexis,
FAC CDR Example
Field Names
Values
globalCallID_callId
100
16777123
16777124
callingPartyNumber
45000
9728134987
9728134987
lastRedirectDn
9728134987
origCause_Value
dest_CauseValue
16
authCodeDescription
Legal1
authorizationLevel
duration
120
And from the SRND;
Cheers!
Rob
thanks for that rob
alexis
alexis
Hey Alexis,
WOW! Great news my friend! Thanks for posting back with your results (+5 )
I'll have to see when this changed.
Cheers!
Rob
