02-11-2017 03:08 AM - edited 03-17-2019 09:29 AM
Hello Cisco,
Our client want to restrict outgoing calls with some pin or password.
I suggested FAC (Force Authorization Code) but it won't fit as required because fac are defined on authorization level not to specific user. e.g. if one user know other's fac, he can use it on any phone to misuse it and in monthly bill genuine user will be in problem.
Is there any solution available in Call Manager 11.0 ?
02-11-2017 04:53 AM
There is no straight forward solution for this. FAC/CMC protection is implemented per route-pattern for all users matching the route pattern.
The only way I see it is to duplicate the route-pattern and assign each to separate PT/CSS. Then each user will have this own CSS to access the route-pattern. Now each route-pattern for each user will have separate FAC.
02-11-2017 04:58 AM
Thank for suggestion Mohammed but its difficult to execute. Here we got 1800+ ip phones.
Any third party solution or suggestion ?
02-11-2017 07:17 AM
I am not aware of any. Let's see if the guys can recommend something
02-11-2017 11:31 AM
Hi there,
Just to add a note to the good tips from my friend Mohammed (+5). You could look into this 3rd party product/service;
https://www.andtek.com/communications-products-lockout.html
Cheers!
Rob
