11-19-2014 08:19 AM - edited 03-17-2019 01:01 AM
Dear Team,
We are planning to put FAC on SIP (7821) phones for calling long distance.
CME version is 10.0
Please find the config
gw-accounting aaa
aaa new-model
aaa authentication login h323 local
aaa authorization exec h323 local
aaa authorization network h323 local
aaa session-id common
voice register global
mode cme
source-address 10.X.X.X port 5060
timeouts interdigit 5
max-dn 500
max-pool 475
load 7821 sip78xx.10-2-1-12
authenticate register
authenticate realm router.local
timezone 35
tftp-path flash:
create profile sync 0003478159444525
voice lpcor enable
voice lpcor custom
group 1 national-FAC
voice lpcor policy national-FAC
service fac
accept national-FAC fac
application
package auth
param max-retries 0
param passwd-prompt flash0:/enter_pin.au
param abort-digit *
param user-prompt flash0:/enter_account.au
param passwd 12345
param term-digit #
param max-digits 32
username 1111 password 7 1446435A5D
voice register pool 2
lpcor type local
lpcor incoming national-FAC
lpcor outgoing national-FAC
busy-trigger-per-button 1
id mac F09E.636F.0F4B
type 7821
number 1 dn 2
template 1
cor incoming NATIONALACCESS 1 3002
dtmf-relay rtp-nte sip-notify
username user2 password cisco
codec g711ulaw
voice register dn 2
number 3002
call-forward b2bua noan 5000 timeout 20
allow watch
name 3002
label 3002
dial-peer voice 117 voip
destination-pattern 905[0256].......$
session protocol sipv2
session target ipv4:10.X.X.X
incoming called-number .
codec g711ulaw
no vad
label 3004
CME#dir flash:
Directory of flash0:/
1 -rw- 96910452 Oct 21 2014 03:35:18 +04:00 c3900e-universalk9-mz.SPA.153-3.M3.bin
2 -rw- 3064 Oct 21 2014 03:49:06 +04:00 cpconfig-39xx.cfg
3 drw- 0 Nov 12 2014 14:09:54 +04:00 its
14 drw- 0 Nov 12 2014 15:16:46 +04:00 GUI
32 drw- 0 Oct 21 2014 03:49:32 +04:00 ccpexp
273 -rw- 2464 Oct 21 2014 03:51:18 +04:00 home.shtml
274 -rw- 116608 Nov 12 2014 15:10:32 +04:00 CME-GUI.rar
275 -rw- 3090800 Nov 12 2014 16:35:04 +04:00 kern78xx.10-2-1-12.sbn
276 -rw- 36307280 Nov 12 2014 16:36:00 +04:00 rootfs78xx.10-2-1-12.sbn
277 -rw- 364072 Nov 12 2014 16:36:10 +04:00 sboot78xx.10-2-1-12.sbn
278 -rw- 1228 Nov 12 2014 16:36:32 +04:00 sip78xx.10-2-1-12.loads
279 -rw- 496521 Nov 12 2014 17:01:40 +04:00 music-on-hold.au
280 -rw- 23660 Nov 19 2014 14:48:40 +04:00 enter_account.au
281 -rw- 24164 Nov 19 2014 14:48:48 +04:00 enter_pin.au
261324800 bytes total (120594432 bytes free)
But when ever iam trying mobile calls call is disconnecting. please find the debugs
Nov 19 20:04:34.661: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_peer:
peer tag 40001, direction 0
Nov 19 20:04:34.661: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
lpcor International-FAC
lpcor International-FAC index 1
Return Lpcor Index 1 for Peer Tag 40001
DAMAC_AKOYA-CME#
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_get_index_by_name:
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_index_is_valid:
lpcor index 1 is valid
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_policy_validate_internal:
Source LPCOR Index=1, Target LPCOR Policy=International-FAC
Nov 19 20:04:39.225: -Traceback= 19E34D6z 581A4DCz 581AC7Fz 55B3588z 55B3063z 55AEA34z 55B6A53z 55B7255z 55B649Bz 55F5AF5z 5583EEFz 55894B6z 5589734z 55F5AF5z 558A44Az 55CF04Ez
DAMAC_AKOYA-CME#
Validate Pass; lpcor (source[1] target[1])
Nov 19 20:04:39.225: //-1/xxxxxxxxxxxx/LPCOR/lpcor_policy_validate_get_service:
FAC is enabled; lpcor (source[1] target[1])
Please advise. If iam missing any steps in this.
LAJAN JALEEL
11-19-2014 10:55 AM
Hello Lajan,
I guess, the LPCOR policy applied in dial-peer, do not exists in configuration:
codec g711ulaw
no vad
As per configuration snip pasted above, and what applied in voice register pool it should be, International-FAC
lpcor type local
lpcor incoming International-FAC
lpcor outgoing International-FAC
It should work, after updating correct policy on dial-peer.
Amit
11-19-2014 11:07 AM
Dear Amit,
Thanks for your reply.
That was a mistake while pasting the config.
lpcor type local
type 7821
|This is the real config. this config is not working.
Kindly advise.
11-19-2014 11:12 AM
Hi ,
It should be lpcor incoming , tag should be exactly same what you have configured while defining LPCOR policy:
if this is real config for lpcor policy:
voice lpcor policy International-FAC
service fac
then both dial-peer and voice register pool should be having same TAG, which is " International-FAC"
if that's same and still its failing, then please collect below said debug in addition to what you have collected already:
debug voip application auth
Amit
11-19-2014 11:31 AM
Dear Amit,
Will try the same and update.
So that means iam not missing any steps right? What ever i was doing is right only some things needs to be changed right?
11-20-2014 04:30 PM
Dear Amit,
The configuration is working fine. We find out what is the exact issue.
*****Issue******
Debug voice application auth was giving an out put that
user prompt url is not found , Even though the exact directory was there under flash0:
CME#dir flash:
my application configuration was like this:
application
package auth
param max-retries 0
param term-digit #
param abort-digit *
param passwd 12345
param max-digits 32
*****Resolution*****
changed user prompt and password prompt from flash0:/ to flash:/
application
package auth
param passwd-prompt flash:/enter_pin.au
param max-retries 0
param term-digit #
param user-prompt flash:/enter_account.au
param abort-digit *
param passwd 12345
param max-digits 32
Right now lpcor is working fine for Long Distance calls with the same config.
Thanks All
