11-10-2013 08:36 PM - edited 03-16-2019 08:19 PM
We have CUCM 9.1 with 3905 and 6921 phones, both phones are running SIP. 6921 working with FAC, but 3905 not working with FAC, when we enter FAC its not getting the PIN number,
Please guide to resolve this, is there any specific configuration for 3905 with FAC
Regds
Solved! Go to Solution.
11-11-2013 10:59 PM
Yes, it is. Please check the resolved caveats in the release notes
Manish
11-11-2013 12:44 AM
Hi Fernando,
What is the firmware on 3905 and are you using variable length route patterns?
You could be running into the following
http://tools.cisco.com/Support/BugToolKit/search/getBugDetails.do?method=fetchBugDetails&bugId=CSCty26479
| 3905 unable dial to variable length route pattern with FAC | |
Symptom:When dialing a variable length route patten such as 9011! or 900! the call is unable to be completed.Conditions:This will occur on a 3905 model phone if Forced Authorization Code is enabled on the route pattern.Workaround:Remove the requirement for Forced Authorization Code from the route pattern OR Use a non-variable length route pattern by adding a # to the route pattern, such as 9011!# or 900!#. Instruct users to dial a # after variable length number. HTH Manish | |
11-11-2013 05:45 AM
Is this Fixed in latest Firmware ? 9.4 ?
Regds
11-11-2013 10:59 PM
Manish
11-12-2013 07:22 AM
11-16-2013 06:45 PM
Hi Manish
Thanks for the info,
Regds
