06-27-2013 01:35 PM - edited 03-16-2019 06:07 PM
Hello Guys,
Good Day! I like to know is there an option available to edit the existing FAC codes on the CUCM.
Thanks.
Solved! Go to Solution.
06-27-2013 01:55 PM
06-27-2013 01:55 PM
No, you can delete and insert FACs with BAT.
HTH,
Chris
07-10-2013 10:23 AM
I'm not so sure about that. The BAT > Export/Import options allows Forced Authorization Codes as an export option. This would give you the existing codes as well as the CSV format needed for an import job. I think it's worth a shot.
Please remember to rate helpful responses and identify helpful or correct answers.
07-10-2013 04:03 PM
Jonathon is correct. Using BAT, export the existing FAC's, make the necessary changes, then import.
JP
Sent from Cisco Technical Support Android App
