1742
smartsoft
Beginner
Factory Reset Error - UC540
I am trying to factory reset a UC540 (reconfiguring IP to allow use on a network with a DHCP server).
When I run the CCA "Factory Reset" command, I end up with  the following error:
"CUE Reset Failed".
I can't run the setup wizard to configure a different IP address. Either I need to be able to resolve not being able to factory reset or can I set the IP address elsewhere.
1 REPLY 1
paolo bevilacqua
Hall of Fame Master
Often the CCA is of little use.
Use CLI and you will be able to do or reset whatever you want.
Create
Recognize Your Peers
Content for Community-Ad
