04-30-2015 02:16 AM - edited 03-17-2019 02:51 AM
hello
When trying to change the value of "Route Partition" in one phone, this error is displayed:
The attempted action was a violation of security protocols and will not be allowed. This may be caused by having multiple concurrent windows open or using browser buttons (back, refresh, etc). Please retry the operation.
there's only one open window, I tested with several web browsers, with the same result.
we proceeded to reboot with the same result
The system is a CCM 10.5.2
someone can tell me if the problem is known.
Best Regards
04-30-2015 04:00 AM
The CUCM documentation implies this "feature" has existed for many years. But I've hit it a lot on CUCM 10.5(2). Never hit it before on previous versions.
GTG
04-30-2015 04:11 AM
04-30-2015 06:03 AM
Hi Jose,
check this discussion with similar issue.
https://supportforums.cisco.com/discussion/12236246/cucm-error
regds,
aman
01-16-2018 01:32 AM
When you apply particular Partition on Route Partition, before clicking >> Save, First Click >> Apply Config, after that Click >> Save
I try it & its work very well in 10.5.2 CUCM
