Failed to change the partition of a terminal
Jose Maria Baeza
Beginner
Beginner
hello
When trying to change the value of "
Route Partition" in one phone, this error is displayed:
The attempted action was a violation of security protocols and will not be allowed. This may be caused by having multiple concurrent windows open or using browser buttons (back, refresh, etc). Please retry the operation.
there's only one open window, I tested with several web browsers, with the same result.
we proceeded to reboot with the same result
The system is a CCM 10.5.2
someone can tell me if the problem is known.
Best Regards
4 REPLIES 4
Gordon Ross
Engager
Engager
The CUCM documentation implies this "feature" has existed for many years. But I've hit it a lot on CUCM 10.5(2). Never hit it before on previous versions.
GTG
Please rate all helpful posts.
In previous versions this problem has not been presented to me.
In this installation I was presented the problem,
and I do not know if it's a general problem or a particular problem in my installation
Best Regards
Hi Jose,
check this discussion with similar issue.
https://supportforums.cisco.com/discussion/12236246/cucm-error
regds,
aman
When you apply particular Partition on Route Partition, before clicking >> Save, First Click >> Apply Config, after that Click >> Save
I try it & its work very well in 10.5.2 CUCM
