889
julienf28
Beginner
Failed Upgrade UCM 7.1.3 to 8.5.1
       Unity connection worked fine but for some odd reason UCM isn't working. It fails after about 1 hour or so.
Attached is the log file. Thanks,
J
11 REPLIES 11
testeven
HI,
How much RAM memory you have on the server? For 8.5 versions, 4 GB is strongly recommended.
From the log file I see this:
E5606  @ 2.13GHz, 3072 MB Memory:
Tere.
If you find this post helpful, please rate!
Regards, Tere. If you find this post helpful, please rate! :)
Strongly recommended but not a min requirement. We do have 3GB but I doubt this is the issue. I will upgrade to 4 on monday and try again.
Thx
Julien
sent from my BlackBerry----
You might want to try a new media.
Please rate useful posts
Please rate all useful posts
This media was given to me by cisco. They are looking through the upgrade logs also. Just hopping somebody had this issue also
Julien
I have had a media sent directly from cisco, it wont even pass media check test let alone install..I have had a media passed media test and failed after 1hr of install. It may not be a media issue but if you have a different one you may want to try it
nikshah
if possible can you go to RTMT and get the install log, not the date log that you have attached, there should be a file install.log, also can you provide the following.
also from the ssh can you get me
file get inactivelog /cm/trace/dbl/sdi/installdb_l2*
file get activelog /cm/trace/dbl/sdi/installdb_l2*
Here is the install log you requested.
Unfortunately the commands you posted below don’t work in the CLI.
Julien Franche
Systems Administrator
T 613-786-0124
gowlings.com <>
Sorry, I just sent you the xml file. Here are the actual logs.
Julien Franche
T 613-786-0124
gowlings.com <>
Sorry for the late reply Julien.
This is what i see in the logs
Name of the file
It should only be UCSInstall_UCOS_8.5.1.13041-1.sgn.iso, kindly rename the file, this is causing dependencies errors when extracting and installing rpm files
Snippet below
06/04/2012 03:21:39 install_rpm.sh|netdump-server rpm failed to install: trying nodeps(rc=1)|<:INFO>
06/04/2012 03:21:39 install_rpm.sh|Installing netdump-server-0.7.16-15.i386.rpm with --nodeps|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/8.5.1.13041-1/RPMS/netdump-server-0.7.16-15.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) error: Failed dependencies:|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE)     /usr/sbin/sshd is needed by netdump-server-0.7.16-15.i386|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|[212/213]: dhcp-3.0.1-68.el4.i386.rpm|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/8.5.1.13041-1/RPMS/dhcp-3.0.1-68.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
06/04/2012 03:21:39 install_rpm.sh|[213/213]: sysstat-5.0.5-25.el4.i386.rpm|<:DEBUG>
06/04/2012 03:21:40 install_rpm.sh|(CAPTURE) warning: /common/rpm-archive/8.5.1.13041-1/RPMS/sysstat-5.0.5-25.el4.i386.rpm: V3 DSA signature: NOKEY, key ID db42a60e|<:DEBUG>
06/04/2012 03:21:40 install_os|Generating /etc/modprobe.conf|<:INFO>
Can you rename the file to the format i have given and retry the install.
i.e
UCSInstall_UCOS_8.5.1.XXXXX-Y.sgn.iso
MD5 checksum  : e9fac7144f4060014136b01af62067b6
hope this helps
Thanks for the tip, Unfortunately, this is a Media CD given to me by Cisco because our PUT wasn’t working. I will ask them to produce another CD with what you suggested.
Julien Franche
Systems Administrator / Ottawa
Tél./Tel. 613-786-0124
gowlings.com <>
Changing the name for the install didn't work and I confirmed that the MD5 checksum matched.
Attached are the install logs and alos the CLI active and inactive install db logs.
thanks,
Julien
Create
Recognize Your Peers
Content for Community-Ad
