1583
Highlighted
Beginner
Beginner
Failover between two SIP trunks (CUBE) take long Time Issue
Dears ,
we have issue  of long time of failover between two SIP Trunks of two CUBE on CUCM.
Our scenario as below
CUCM (PUB-SUB) ----SIP TRUNK 1 -----CUBE 1----SIP----Telco (SIP Service UP from telco)
CUCM (PUB-SUB) ----SIP TRUNK 2 -----CUBE 2----SIP----Telco (SIP Service Down )
We set SIP Trunk1 in RG1 , SIP Trunk2 in RG2 .
Normal Case
Standard Route list Contains ( RG1 then RG2 )
when we try outbound calls , calls success with out any delay .
Failover Case
Standard Route list Contains ( RG2 then RG1 )
when we try outbound calls , calls success but with high delay about 60 seconds  or more.
we modify these setting under service parameters but without luck
set Retry Count for SIP Invite to be 2
set SIP Trying Timer  to be 200
Please Advice
Everyone's tags (1)
1 ACCEPTED SOLUTION
Highlighted
VIP Advisor
Re: Failover between two SIP trunks (CUBE) take long Time Issue
Have you tried these commands on the CUBE.
sip-ua
retry invite 3
timers trying 200
Also, do you have options ping configured on your cubes. This will busy-out
the dialpeers when no service and when cucm sends invite cube will respond
with 503 message immediately without waiting for provider to timeout.
6 REPLIES 6
Highlighted
Is the SIP trunk on the secondary CUBE always registered/ACTIVE ? 60 seconds is a huge delay. I doubt it is either CUCM or CUBE.
Can you take a log from the RG2 CUBE ? Also, what happens if you point SIP trunk 2 directly on the RP bypassing SLRG/RG ?
Nipun Singh Raghav
"We cannot solve our problems with the same thinking we used when we created them"
Highlighted
Beginner
Beginner
Now , we set RP to point directly to SIP Trunk-2  (Which Cube has no sip service from telco), it takes long time to get fast busy tone about 60 s
Kindly find attached run config and output of below debugs
debug voip ccapi inout
debug ccsip messages
Highlighted
VIP Advisor
sip-ua
retry invite 3
timers trying 200
Highlighted
Beginner
Beginner
Hello Mohamed ,
Thanks for your support ,
The issue has been fixed after adding these configs
sip-ua
retry invite 3
timers trying 200
Also Allow keep alive for all dial peers for ISIP
dial-peer voice X voip
voice-class sip options-keepalive
Highlighted
VIP Advisor
Great news. Please mark the question as answered.
Highlighted
Beginner
Beginner
I Accepted your solution already
Content for Community-Ad
Future of Work Virtual Summit Day 5
Cisco COVID-19 Survey
