Fallback-DN Removal
Will Castle
I'm trying to remove/delete a fallback-dn in the VG450 Gateway. I was able to delete the DN manually within the CUCM, but when I view the stcapp supplementary-services, it's still being displayed. How do I remove/delete it from the stcapp supplementary-services, if that's possible. See attachment for what I'm wanting to delete.
port 3/0/39
no fallback-dn
Response Signature
10 Replies 10
on VG config:
no stcapp supplementary-services
no port X/X/X
Carlo
Please rate all helpful posts "The more you help the more you learn"
This is what's happening when I input the commands...see attachment
Please post your VG config
Carlo
I'm still learning the Cisco CM, so please forgive me for asking how do I get that or get to that?
No worries Will,
On VG issue show run command
Cheers
Carlo
port 3/0/39
no fallback-dn
Response Signature
Will Castle
Merci Beaucoup Gents for the assistance. I was in the correct rabbit hole, but wrong tunnel. lol
Will Castle
Since I have you guys attention, quick question...can the time on the phone (Cisco 7841) be adjusted locally? It's currently 30 minutes ahead of the actual time.
No. The phone gets it’s time from the CM.
Response Signature
More specifically, the timezone listed in the Date/Time Group (assigned via Device Pool) will determine what time appears on a phone. If no DTG is specified, the phone will show the time in the CM Local (set during system installation).
Maren
