Fast track configuration for cisco ip phone 7811 CME 10.5 lose the features or not ?? help please !!
Gezimvatovci
If I go with fast track for ip phone 7811 and 7821 on CME 10.5 do i lose the features ? I mean the features Cfwdall,pickup,gpickup.
 Cfwdall, Pickup, Gpickup. and other features ??
with this configuration:
voice register pool-type 7811
xml-config maxNumCalls 4
xml-config busyTrigger 4
description Cisco IP Phone 7811
reference-pooltype 6921
Thanks a lot,
GV
Deepak Rawat
GV,
For 78XX phones , the closest model is the 69XX phones which can be used as Device Reference. 69XX phones fall in the category of RTL and URTL family and both of them support features such as HOLD, XFER, FWDALL, CONFRN, NEWCALL, ENDCALL and CONFLIST so it should work for your 78XX phones as well.
https://supportforums.cisco.com/document/12210701/fast-track-support-sip-phones
Deepak
- Rate Helpful Posts -
Deepak Rawat
GV,
Deepak
Dear Deepek,
As per the document we configued the Phone configuration in CME 10.5 , All other phones are registered except 7811, Please find the below configuratin for the 7811 phones.
Note: Reference pool-type instead of 6921, we tried 6911 also. phone getting DHCP from CME, but can't able to ping from CME.
xml-config busyTrigger 2
telnet-support
gsm-support
transport tcp
num-lines 4
addons 2
voice register dn 94
number 3004
allow watch
name 3004
label 3004
mwi
voice register pool 94
busy-trigger-per-button 1
id mac 9C57.ADD2.C68F
type 7811
number 1 dn 94
dtmf-relay rtp-nte
ephone-dn 94
number 3004
label 3004
name 3004
ephone 94
mac-address 9C57.ADD2.C68F
max-calls-per-button 2
type 6921
button 1:94
Please Advise.
Mohamed
