10-24-2012 03:02 PM - edited 03-16-2019 01:52 PM
Hi all,
Hoping someone can shed some light on this issue we've been having. We have a fax machine or rather several that cannot seem to fax to a particular number. I called the outside contact and was told that we are the only location that they cannot recieve a fax from. When I tried to fax to them, I hear the fax tone but it drops after 1 or 2 rings then retries a few seconds later. I've done some digging on my own and even tried some debugging but to no avail mostly because I cant make heads or tails out of the output.
Any ideas where to start troubleshooting would be appreciated...
Thanks.
Ray
10-24-2012 04:09 PM
Give us an idea of what your side of the picture looks like. What type of Cisco hardware? LAN/WAN? What's between the FXS port and the PSTN? What type of PSTN connectivity? IOS and software/firmware version? What's being used: Cisco Fax Relay/T.38 Relay/Fax Passthrough/Modem Passthrough/Modem Relay?
10-26-2012 11:56 AM
Hi Jonathan,
Sorry for the late response, here is our setup:
CCM 8.6 Publisher and Subscriber
CUC 8.6 x 2 for redundency
VG224 x 18 for analog / for patient rooms and fax machines, configured mgcp
We have a redundant PRI T1 coming in from Windstream.
I have a log from our 2 2901 routers that act as our voice gateways.
I have also wondered should we be using t.38 relay?
Thanks for your help and let me know if you need any other info.
~Ray
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2012.10.26 13:46:00 =~=~=~=~=~=~=~=~=~=~=~=
MRH-VOICE-RTR1#sh mgcp
MGCP Admin State ACTIVE, Oper State ACTIVE - Cause Code NONE
MGCP call-agent: 10.100.4.11 2427 Initial protocol service is MGCP 0.1
MGCP validate call-agent source-ipaddr DISABLED
MGCP validate domain name DISABLED
MGCP block-newcalls DISABLED
MGCP send SGCP RSIP: forced/restart/graceful/disconnected DISABLED
MGCP quarantine mode discard/step
MGCP quarantine of persistent events is ENABLED
MGCP dtmf-relay for VoIP is SDP controlled
MGCP dtmf-relay for voAAL2 is SDP controlled
MGCP voip modem passthrough mode: NSE, codec: g711ulaw, redundancy: DISABLED,
MGCP voaal2 modem passthrough disabled
MGCP voip modem relay: Disabled
MGCP T.38 Named Signalling Event (NSE) response timer: 200
MGCP Network (IP/AAL2) Continuity Test timer: 200
MGCP 'RTP stream loss' timer disabled
MGCP request timeout 500
MGCP maximum exponential request timeout 4000
MGCP rtp unreachable timeout 1000 action notify
MGCP gateway port: 2427, MGCP maximum waiting delay 3000
MGCP restart delay 0, MGCP vad DISABLED
MGCP rtrcac DISABLED
MGCP system resource check DISABLED
MGCP xpc-codec: DISABLED, MGCP persistent hookflash: DISABLED
MGCP persistent offhook: ENABLED, MGCP persistent onhook: DISABLED
MGCP piggyback msg ENABLED, MGCP endpoint offset DISABLED
MGCP simple-sdp ENABLED
MGCP undotted-notation DISABLED
MGCP codec type g711ulaw, MGCP packetization period 20
MGCP JB threshold lwm 30, MGCP JB threshold hwm 150
MGCP LAT threshold lwm 150, MGCP LAT threshold hwm 300
MGCP PL threshold lwm 1000, MGCP PL threshold hwm 10000
MGCP CL threshold lwm 1000, MGCP CL threshold hwm 10000
MGCP playout mode is adaptive 60, 40, 1000 in msec
MGCP Fax Playout Buffer is 300 in msec
MGCP media (RTP) dscp: ef, MGCP signaling dscp: af31
MGCP default package: trunk-package
MGCP supported packages: gm-package dtmf-package trunk-package line-package
hs-package rtp-package atm-package ms-package dt-package
mo-package mt-package sst-package fxr-package pre-package
md-package
MGCP Digit Map matching order: shortest match
SGCP Digit Map matching order: always left-to-right
MGCP VoAAL2 ignore-lco-codec DISABLED
MGCP T.38 Max Fax Rate is DEFAULT
MGCP T.38 Fax is DISABLED
MGCP T.38 Fax ECM is DISABLED
MGCP T.38 Fax NSF Override is DISABLED
MGCP T.38 Fax Low Speed Redundancy: 0
MGCP T.38 Fax High Speed Redundancy: 0
MGCP Fax relay SG3-to-G3: ENABLED
MGCP Fax relay ANSam suppression: DISABLED
MGCP control bind :DISABLED
MGCP media bind :DISABLED
MGCP Upspeed payload type for G711ulaw: 0, G711alaw: 8
MGCP Dynamic payload type for Cisco fax indication: 96, Cisco fax ack: 97
MGCP Dynamic payload type for G.726-16K codec
MGCP Dynamic payload type for G.726-24K codec
MGCP Dynamic payload type for G.726-32K codec
MGCP Dynamic payload type for G.Clear codec
MGCP Dynamic payload type for NSE is 100
MGCP Dynamic payload type for NTE is 99
MGCP rsip-range is enabled for TGCP only.
MGCP Comedia role is NONE
MGCP Comedia check media source is DISABLED
MGCP Comedia SDP force is DISABLED
MGCP g729 variants use static payload type and contain annexb in SDP
MGCP Guaranteed scheduler time is DISABLED
MGCP Disconnect delay error recovery DISABLED
MGCP DNS stale threshold is 30 seconds
MRH-VOICE-RTR1#exit
Edit: I also ran a sh run on the router and we are using "modem passthrough voip mode nse"
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
mgcp package-capability sst-package
mgcp package-capability pre-package
no mgcp package-capability res-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp fax t38 inhibit
mgcp profile default
10-29-2012 10:08 AM
Any body?
~Ray
10-29-2012 10:17 PM
Hey Ray,
From what you described here is the call flow, correct me if i am wrong:
Call flow:
Faxmachine>>>FXS>>MGCP>>>CUCM>>>H323>>>GW>>PRI>>>PSTN
Fax protocol:
modem passthrough nse based.
Question's:
1> Are voice calls possible from site where you are trying to send fax from?
Can attach the following show commands:
show tech (from vg224 & voice GW)
Let me know the same.
Kevin
