Fax Machine problem
muratg7777
Beginner
Beginner
Hi Folks;
We have UC520. On Fxs port - Fax Machine is connected.
We are faxing without problem. The problem is, when we fax it uses random analog liner.
We have 4 analog lines. I want to configure that on outgoing faxes, the fax machine shoud only use fxo port 0/1/0.
I have tried ro configure cor list but it did not worked.
How can I configure a fax machine to use only 1 analog line.  don't want to dedicate it to fax machine, on outgoing calls, all 4 analog line must in use
voice-port 0/0/0
cptone TR
description FAX
station-id name Fax Machine
station-id number 191
caller-id enable
voice-port 0/1/0
trunk-group ALL_FXO 64
cptone TR
timeouts call-disconnect 3
timeouts wait-release 3
connection plar opx 191
description Configured by CCA FAX-Custom-OP
caller-id enable
Remove all other dial-peers and use the configuration provided below.I have modified it.
voice-port 0/0/0
cptone TR
description FAX
caller-id enable
voice-port 0/1/0
cptone TR
caller-id enable
Dial-peer cor custom
  name fax
dial-peer cor list block-from-fax
member phones
dial-peer cor list fax-only
member fax
dial-peer voice 1 pots
description  ****To Fax MAchine***
destination-pattern 191
no digit-strip
port 0/0/0
forward-digits 0
no sip-register
dial-peer voice 58 pots
trunkgroup ALL_FXO
description ** Phone Zero Dialing***
preference 5
destination-pattern 90..........
forward-digits all
no sip-register
corlist outgoing block-from-fax
dial-peer voice 59 pots
trunkgroup ALL_FXO
description ***Phone Local  dialing**
no translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 9[2-9]......
forward-digits all
no sip-register
dial-peer voice 60 pots
description **Incoming Dial-peer from Fax***
answer-address 191
port 0/0/0
corlist incoming fax-only
dial-peer voice 61 pots
description *****Fax outgoing Local Calls***
preference 0
port 0/1/0
forward-digits all
corlist outgoing fax-only
no sip-register
dial-peer voice 62 pots
description *****Fax outgoing Zero dialing Calls***
preference 0
port 0/1/0
forward-digits all
no sip-register
Tom
15 Replies 15
paolo bevilacqua
Hall of Fame Master Hall of Fame Master
Hall of Fame Master
Configured correctly, COR should work.
Otherwise, make a translation rule for preper some digits to numbers called from FXS port, have a dial-peer for these digits and the port you want.
Where will I assign the cor list.
I mean, I am creating new dial peer amd assigning corlist to it but the examples are for ephone-dn
I can not assign corlist to ports. Can you give example for it
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a008019d649.shtml
You assign cor-list to dial-peers, not ports.
Maybe the method with number manipulation it's easier for you.
I did that but it didn't work
name ip
name fax
Dial-peer cor list ip
member ip
member fax
trunkgroup ALL_FXO
description **CCA*Generic Locale*Local Number**
preference 5
forward-digits all
no sip-register
corlist outgoing ip
trunkgroup ALL_FXO
description Lokal
preference 5
forward-digits all
no sip-register
corlist outgoing ip
description Fax_ic
preference 5
port 0/0/0
forward-digits all
no sip-register
description Fax_ic
preference 5
port 0/0/0
forward-digits all
no sip-register
I also tried corlist incoming and it did not work. Both ip phones and fax machine dials exactly the same
numbers so destination patterms are the same.
also I tried translation rule :
voice translation-profile Phone1
translate called 1
voice translation-rule 1
rule 1 /^9/ /5551111/
translation-profile incoming Phone1
preference 5
port 0/0/0
forward-digits all
no sip-register
preference 5
port 0/0/0
forward-digits all
no sip-register
9 for picking up analog line and 5551111 is my fax number
HI ,
No need to put any translation rules for the fax issue.
Now the Idea is to associate your fxs port initated calls  with the corlist
create a specific dial-peer to match all you calls from fax machines using a dial-peer similar to following.
dial-peer voice 55 pots
answer-adress  7000     (I assume your fax machine internal extension as 7000)
port 0/2/0   (FXS port)
Tom
Hi Tom;
I tried you config but when I call external numbers, it calls to fax machine's extension.  It forwards all calls to fax machine.
I also bind cor list to all ephones
ephone-dn  67  dual-line
corlist outgoing ip
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
description Lokal
preference 5
forward-digits all
no sip-register
corlist incoming ip
description Fax_external
preference 5
answer-address 191
port 0/0/0
forward-digits all
no sip-register
corlist incoming ip
description Fax_local
preference 5
answer-address 191
port 0/0/0
forward-digits all
no sip-register
also tried
corlist incoming ip
and outgoing cor list on dial peer 58 and 59
Don't put corlist on ephone-dn, so they will be free to use any DP.
Put precedence 1 on the DP for the fax FXO, so the the ephones will not use it.
You only need a corlist, not two.
trunkgroup ALL_FXO
description Lokal
preference 5
forward-digits all
no sip-register
answer-address 191
port 0/0/0
forward-digits 0
no sip-register
I removed preference value and ephones corlist, it fixes the problem but  still fax machine goes from random analog lines.
Now you need an incoming DP with the FXS port of the fax.
DP 61 needs no corlist, and the preferences reversed.
I already have DP for incoming
description ** CCA Analog Fax **
no digit-strip
port 0/0/0
forward-digits 0
no sip-register
I don't have problem with incoming faxes. Need to bind fax machine to , FXS 0/0/0 to FXO 0/1/0 for outgoing faxes
Could anyone can post a full config???
I almost tried everything and it is not working.
I want to do a simple thing.
Here is my latest config:
voice-port 0/0/0
cptone TR
description FAX
caller-id enable
voice-port 0/1/0
cptone TR
caller-id enable
no digit-strip
port 0/0/0
forward-digits 0
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
description Lokal
preference 5
forward-digits all
no sip-register
preference 10
answer-address 191
port 0/0/0
forward-digits all
no sip-register
preference 10
answer-address 191
port 0/0/0
forward-digits all
no sip-register
Is it a UAE Dialplan ?
No Turkey.
2-9 is for local calls
90 is for out of town.
voice-port 0/0/0
cptone TR
description FAX
caller-id enable
voice-port 0/1/0
cptone TR
caller-id enable
  name fax
member phones
member fax
no digit-strip
port 0/0/0
forward-digits 0
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
trunkgroup ALL_FXO
preference 5
forward-digits all
no sip-register
answer-address 191
port 0/0/0
preference 0
port 0/1/0
forward-digits all
no sip-register
preference 0
port 0/1/0
forward-digits all
no sip-register
Tom
Recognize Your Peers
