09-12-2017 01:57 AM - edited 03-17-2019 11:09 AM
I have 2 site, one is HQ and second is Site B, HQ have fax machine (688) connected on a FXS during router, and Site B have router have FXS and connected fax machine (7614), I tried to send fax from Site B (7614) to HQ (688) but failed. and from (688) to (7614) is working proberly.
In attachment sh run for 2 site and debug voice ccapi inout for Site B
09-12-2017 02:52 AM
09-12-2017 04:12 AM
Hi Abhay,
I tried but busy tone not ringing. and i tried to add this dial-peer also
dial-peer voice 688 voip
destination-pattern 688
session protocol sipv2
session target ipv4:10.10.11.254
dtmf-relay cisco-rtp rtp-nte h245-signal h245-alphanumeric
codec g711ulaw
fax rate disable
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback cisco
no vad
and the dest fax rings but no answer. in attachment the debug on two router HQ and Site B.
You should to know the router HQ is registered on CUCM v10.5
09-12-2017 07:26 AM
