Fax on SIP-TRUNK
clark white
Level 2
Level 2
I am facing issues with FAX connecting to ATA 186 they are not able to send fax nor they are able to receive, but if i am connecting anolog phone the call is perfect for in and out ,
Can anybody help me to know what are the standards commnds to put when the VG is in a SIP Trunk.
5 Replies 5
Chris Deren
ATA186 do not support protocol based T38 which is what most likely your provider is using. Your options are:
1. Get device that supports T.38, i.e. ATA187
2. Check wit provider to see if they can use fax passthrough and reconfigure your GW to use it.
HTH,
Chris
Thanks Chris,
Can u tell me the commands to applied on my VG  once i make agree my provider to configure fax passthrough on his end.
"modem passthrough nse codec g711ulaw"
Either under dial-peer or voice service voip global settings.
HTH, please rate all useful posts!
Chris
Thanks Chris,
Can you guide me for debugs commands to be confirmed that fax traffic is passng through my VG on SIP TRUNK to my provider.
debug ccsip messages
show call active voice brief
Chris
