FAX Over IP Issue
atrin.saghebfar
Hello to all
my voip network is as attachment pic.
so i want to use fax on my network, and for using that i install 1 VG-224-FXS on my network
i config vg224 as MGCP gateway,so i can call numbers in CUCM and can recieve fx from outside of the company
the problem is, ,when i want to send fax, the fax connection is faile, but there is only one another issue, when i send fax via the route pattern which route calls to 3640 i can send fax, but if fax route via 5350 nad E1 it fails at negotiation
could please someone help me
atrin
here is my VG224 config:
ccm-manager redundant-host 192.168.16.10
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server 192.168.16.10
ccm-manager config
ccm-manager config dialpeer-prefix
mgcp
mgcp call-agent 192.168.16.11 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
no mgcp timer receive-rtcp
mgcp sdp simple
no mgcp fax t38 ecm
mgcp rtp payload-type g726r16 static
mgcp profile default
dial-peer voice 20 pots
service mgcpapp
port 2/0
dial-peer voice 99920 pots
service mgcpapp
port 2/0
5 Replies 5
atrin.saghebfar
here is my AS5350 config:
voice service voip
modem passthrough none codec g729r8 pre-ietf
voice translation-rule 1
rule 1 /805/ //
voice translation-rule 2
rule 1 /^6/ /8056/
rule 2 /6100/ /8056100/
rule 3 /6204/ /8056204/
voice translation-rule 3
rule 1 /6100/ /8056100/
rule 2 /..../ /805/
voice translation-rule 4
rule 1 /^6/ /8056/
voice translation-profile DID
translate calling 1
translate called 1
voice translation-profile MBL_CLID
translate calling 4
voice translation-profile OUT
translate calling 2
controller E1 3/0
pri-group timeslots 1-31
controller E1 3/1
controller E1 3/2
controller E1 3/3
interface GigabitEthernet0/0
ip address 192.168.16.22 255.255.255.0
duplex auto
speed auto
negotiation auto
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
negotiation auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no fair-queue
interface Serial0/1
no ip address
shutdown
clock rate 2000000
interface Serial3/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-net5
isdn incoming-voice data
no cdp enable
interface Serial3/1:15
no ip address
encapsulation hdlc
no cdp enable
ip route 0.0.0.0 0.0.0.0 192.168.16.1
no ip http server
control-plane
voice-port 3/0:D
cptone DE
voice-port 3/1:D
cptone DE
dial-peer voice 2 voip
voice cut-through alert
translation-profile outgoing OUT
preference 2
destination-pattern 6...
progress_ind setup enable 3
session target ipv4:192.168.16.10
codec g711ulaw
fax protocol pass-through g711ulaw
no vad
dial-peer voice 1 pots
translation-profile incoming DID
destination-pattern .......$
no digit-strip
direct-inward-dial
port 3/1:D
dial-peer voice 3 voip
incoming called-number 0
codec g711ulaw
no vad
supplementary-service pass-through
dial-peer voice 4 pots
destination-pattern 9999
direct-inward-dial
port 3/1:D
dial-peer voice 5 voip
destination-pattern 8052
session target ipv4:192.168.16.21
codec g711ulaw
no vad
dial-peer voice 6 voip
destination-pattern 2...
codec g711ulaw
no vad
dial-peer voice 7 pots
translation-profile outgoing MBL_CLID
huntstop
destination-pattern 0
no digit-strip
port 3/1:D
dial-peer voice 9 pots
destination-pattern 99999
direct-inward-dial
port 3/0:D
dial-peer voice 8 pots
destination-pattern 0...$
direct-inward-dial
port 3/0:D
dial-peer voice 10 voip
huntstop
incoming called-number .......$
codec g711ulaw
no vad
dial-peer voice 11 pots
preference 2
incoming called-number 80.....$
no digit-strip
direct-inward-dial
port 3/0:D
dial-peer voice 13 pots
destination-pattern 021.....$
port 3/1:D
forward-digits all
dial-peer voice 14 pots
port 3/1:D
forward-digits all
dial-peer voice 15 voip
shutdown
destination-pattern 6531
session target ipv4:192.168.16.32
dial-peer voice 12 voip
destination-pattern 69..
session target ipv4:10.21.209.227
codec g711ulaw
no vad
dial-peer voice 110 pots
destination-pattern 0541.......
direct-inward-dial
port 3/1:D
forward-digits 7
dial-peer voice 119 pots
destination-pattern 23...........
direct-inward-dial
port 3/0:D
forward-digits 11
dial-peer voice 123 voip
destination-pattern 6698
codec g711ulaw
no vad
dial-peer voice 124 pots
destination-pattern 0541118$
direct-inward-dial
port 3/1:D
forward-digits 3
The important thing is to make sure your fax transport methods match on the vg224 and the 5350.  On the vg, you have modem passthrough, t38, and Cisco fax relay enabled (t38 and Cisco fax relay are enabled by default).  However, you have none of these enabled on the 5350.  Are you trying to use the dial-peer config for your fax negotiation?  If so, you can use T38, which seems to be a bit more reliable.  The easiest way to do this is to enable t38 globally (not on the dial peers), just in case you are not hitting the dial peers you are intending to.  Try the following config changes:
ON THE VG224:
config t
no ccm-manager fax protocol cisco
mgcp default-package fxr
no mgcp
mgcp
ON THE 5350:
remove 'fax protocol pass-through' under the dial peers
config t
voice service voip
fax protocol t38 ls 0 hs 0 fallback pass-through g711ulaw
Also, make sure there are no slips/errors on the PRI's on the 5350 (show controllers e1)
Dear Christopher
thank for your replay
but i do all you said, and i'm still have problem
i think at this time i find the problem, but didnt know how can in solve that, if i call the fax machine via E1 ports i can only here the fax tone only for 1 sec and after that any tones not hear, i think the connection was lost
and if i test by two faxes in each end point, the tranmited fax said that "Error in Transmition"
maybe its becasue of my E1 line, which can not handle fax or modem tones
and i also test with modem pass through , and all the same
atrin.saghebfar
here are my both new config:
__AS5350__
version 12.4
hostname VGW-002
boot-start-marker
no boot startup-test
boot-end-marker
resource-pool disable
no aaa new-model
resource policy
ip cef
no ip domain lookup
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711ulaw
h323
modem passthrough nse codec g711alaw
rule 1 /805/ //
rule 1 /^6/ /8056/
rule 2 /..../ /805/
rule 1 /^6/ /8056/
translate calling 1
translate called 1
translate calling 4
translate calling 2
controller E1 3/0
controller E1 3/1
controller E1 3/2
controller E1 3/3
duplex auto
speed auto
negotiation auto
no ip address
shutdown
duplex auto
speed auto
negotiation auto
interface Serial0/0
no ip address
shutdown
clock rate 2000000
no fair-queue
interface Serial0/1
no ip address
shutdown
clock rate 2000000
no ip address
encapsulation hdlc
no cdp enable
no ip address
encapsulation hdlc
no cdp enable
ip default-gateway 192.168.16.1
no ip http server
control-plane
voice-port 3/0:D
cptone DE
voice-port 3/1:D
cptone DE
preference 2
session target ipv4:192.168.16.11
codec g711ulaw
no vad
no digit-strip
direct-inward-dial
port 3/1:D
codec g711ulaw
no vad
direct-inward-dial
port 3/1:D
codec g711ulaw
no vad
codec g711ulaw
no vad
huntstop
no digit-strip
port 3/1:D
direct-inward-dial
port 3/0:D
direct-inward-dial
port 3/0:D
huntstop
codec g711ulaw
no vad
preference 2
no digit-strip
direct-inward-dial
port 3/0:D
port 3/1:D
forward-digits all
port 3/1:D
forward-digits all
shutdown
codec g711ulaw
no vad
direct-inward-dial
port 3/1:D
forward-digits 7
direct-inward-dial
port 3/0:D
forward-digits 11
codec g711ulaw
no vad
direct-inward-dial
port 3/1:D
forward-digits 3
__VG224__
no service pad
hostname VG224FAX
boot-start-marker
boot-end-marker
enable secret 5 $1$/m/l$xw/PKWOpCxOHvDRObER.j.
no aaa new-model
resource policy
voice-card 0
username cisco privilege 15 password 0 cisco
interface FastEthernet0/0
ip address 192.168.16.27 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
ip http server
control-plane
voice-port 2/0
voice-port 2/1
voice-port 2/2
voice-port 2/3
voice-port 2/4
voice-port 2/5
voice-port 2/6
voice-port 2/7
voice-port 2/8
voice-port 2/9
voice-port 2/10
voice-port 2/11
voice-port 2/12
voice-port 2/13
voice-port 2/14
voice-port 2/15
voice-port 2/16
voice-port 2/17
voice-port 2/18
voice-port 2/19
voice-port 2/20
voice-port 2/21
voice-port 2/22
voice-port 2/23
ccm-manager mgcp
ccm-manager config
mgcp
mgcp modem passthrough voip codec g711alaw
mgcp default-package fxr-package
mgcp sdp simple
no mgcp fax t38 ecm
service mgcpapp
port 2/0
line con 0
line aux 0
line vty 0 4
login local
hey i found something new
i can send fax to the modem on the pc, but still cannot send fax to any fac-machine, i check with 3 different fax-machine types
is there any issue
