Fax over IP via SIP trunk Issue
Hello guys, I have some issues with Fax over IP via SIP trunk. The scenarios is:
ITSP-------SIP-trunk--------VoiceGW----SIP-trunk---CUCM--------ATA186------Fax
a few days ago fax stop working. Fax ringing after that starts play annoying FAX signal and failed with error. In ccsip debug I didn't see T38 negotiation. I tried different configuration but without success. I need help to resolve this issue.
My Incoming dial-peer is:
dial-peer voice 1 voip
 description **Incomming-Calls**
 rtp payload-type cisco-codec-ilbc 126
 rtp payload-type nte 116
 session protocol sipv2
 incoming called-number 02T
 dtmf-relay rtp-nte sip-notify
 codec g711alaw
 fax-relay ecm disable
 no fax-relay sg3-to-g3
 fax rate disable
 fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 no vad
My Outgoing dial-peer is:
dial-peer voice 3228 voip
 description **TEST FAX**
 translation-profile outgoing OutFax
 destination-pattern 02974****
 session target ipv4:*.*.*.*
 codec g711alaw
 fax rate disable
 no vad
I attached ccsip debug. It seems not send T38 from my side but why? I received T38 from the other side.
5 Replies 5
Jonathan Schulenberg
The ATA186 doesn't support T.38 faxing, only NSE-based fax passthrough which no SIP carrier I'm aware of supports since it is Cisco-proprietary and part of the media, not signaling, flow. The passthrough feature (not pass-through which is a different thing that the ATA186 also doesn't support) is a relic from when VoIP stopped at the PSTN gateway and was converted back into TDM/analog.
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/ata-180-series-analog-telephone-adaptors/19083-ata-fax.html
http://www.cisco.com/c/en/us/support/docs/voice-unified-communications/unified-border-element/115742-fax-modem-call-flows-00.html#anc6
Since the carrier doesn't support passthrough the call will proceed as a normal voice call, inclusive of whatever the normal voice call codec is, dejiter buffers, VAD (if enabled), etc. You will have very low success rates using this method.
If you want T.38 then you would need to use a VG202/204, the newer ATA190, or an FXS port on an ISR router.
With that said, there is actually a second problem here.
Here's the RE-INVITE from the ITSP requesting a T.38 switchover. Since the ITSP is making the request this must have been an outbound call (the terminating gateway initiates the switchover).
Sep 2 14:34:59.265: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Received:
INVITE sip:02969****@10.102.*.*:5060 SIP/2.0
Via: SIP/2.0/UDP 10.102.*.*:5060;branch=z9hG4bKvbeene206o5blbq7g2k0sb0000g00.1
Call-ID: 3B2B41FE-705111E6-9ADEDC1D-E5C2C1AE@10.102.*.*
From: <sip:02974****@10.102.*.*>;tag=SDrq7r899-vps2grrs-CC-34
To: "fax 2197 - blok 306" <sip:02969****@10.102.*.*>;tag=3E5C794-1DFF
CSeq: 1 INVITE
Contact: <sip:02974****@10.102.*.*:5060;transport=udp>
Max-Forwards: 69
Content-Length: 425
Content-Type: application/sdp
v=0
o=Vivacom 11299122 11299124 IN IP4 10.102.*.*
s=Sip Call
c=IN IP4 10.102.*.*
t=0 0
m=image 20168 udptl t38
a=T38FaxVersion:0
a=T38MaxBitRate:14400
a=T38FaxRateManagement:transferredTCF
a=T38FaxUdpEC:t38UDPRedundancy
m=audio 20282 RTP/AVP 8 0 101
a=rtpmap:8 PCMA/8000
a=rtpmap:0 PCMU/8000
a=rtpmap:101 telephone-event/8000
a=ptime:20
a=silenceSupp:off - - - -
a=ecan:fb on -
a=X-fax
a=fmtp:101 0-15
Which CUBE doesn't include when sending it on to CUCM:
Sep 2 14:34:59.293: //5134/63D7CC800000/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:02969****@10.20.*.*:5060 SIP/2.0
Via: SIP/2.0/UDP 10.20.*.*:5060;branch=z9hG4bK4A922FC
Remote-Party-ID: <sip:02974****@10.20.*.*>;party=calling;screen=no;privacy=off
To: "fax 2197 - blok 306" <sip:02969****@10.20.*.*>;tag=302038~0ca2d289-019a-4842-a7cf-4124ee03f828-25700970
Date: Fri, 02 Sep 2016 14:34:59 GMT
Call-ID: 63d7cc80-7c918e06-5b00-8a04140a@10.20.*.*
Supported: timer,resource-priority,replaces,sdp-anat
Min-SE: 1800
Cisco-Guid: 1675086976-0000065536-0000015771-2315523082
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 101 INVITE
Max-Forwards: 70
Timestamp: 1472826899
Contact: <sip:02974****@10.20.*.*:5060>
Call-Info: <sip:10.20.*.*:5060>;method="NOTIFY;Event=telephone-event;Duration=2000"
Expires: 180
Allow-Events: telephone-event
Content-Length: 212
v=0
o=CiscoSystemsSIP-GW-UserAgent 7524 6021 IN IP4 10.20.*.*
s=SIP Call
c=IN IP4 10.20.*.*
t=0 0
m=audio 17516 RTP/AVP 8
c=IN IP4 10.20.*.*
a=ptime:20
Your call is not matching the dial-peers you expect it to. Instead, it appears to be matching dial-peer 0. As evidence of this, notice that the RE-INVITE to CUCM is offering only G.729 even though your dial-peers are configured with G.711 a-law.
Because of this CUCM never thinks to offer T.38 in the response, though it wouldn't have even if given the option since the ATA186 doesn't support T.38. When CUBE eventually responds to the ITSP to finish the media renegotiation, it rejects the T.38 switchover by setting the UDP port to zero. Worse still is that it only offers G.729 which will never work for fax calls. This is why the carrier responds with a BYE.
Sep 2 14:34:59.373: //5135/63D7CC800000/SIP/Msg/ccsipDisplayMsg:
Sent:
SIP/2.0 200 OK
CSeq: 1 INVITE
Remote-Party-ID: "fax 2197 - blok 306" <sip:02969****@10.102.*.*>;party=called;screen=yes;privacy=off
Contact: <sip:02969****@10.102.*.*:5060>
Supported: replaces
Supported: sdp-anat
Server: Cisco-SIPGateway/IOS-12.x
Supported: timer
Content-Length: 424
v=0
o=CiscoSystemsSIP-GW-UserAgent 2147 9635 IN IP4 10.102.*.*
s=SIP Call
c=IN IP4 10.102.*.*
t=0 0
m=image 0 udptl t38
c=IN IP4 10.102.*.*
a=T38FaxVersion:0
Voice_GW-2#redTCF
m=audio 18726 RTP/AVP 8
c=IN IP4 10.102.*.*
a=ptime:20
You should review your dial-peer configuration to see why calls aren't matching what you expect them to. The best you can hope for here is a normal G.711 voice call with the analog fax transmission carried within it. In practice, this isn't reliable: a single lost/delayed/out-of-order RTP packet can cause the whole page to fail transmission.
Hello Jonathan,
I checked the dial-peer and are correct. I've change the configuration and upgrade the ATA to the latest firmware but still no success.
voice service voip
 fax protocol t38 nse force version 0 ls-redundancy 0 hs-redundancy 0 fallback pass-through g711alaw
 modem relay nse codec g711alaw gw-controlled
 modem passthrough nse codec g711alaw
 dtmf-relay h245-alphanumeric
 codec g711alaw
 fax rate 9600
 no vad
 description **TEST FAX Topica**
 translation-profile outgoing Out_Vivacom
 destination-pattern 02974T
 progress_ind setup enable 3
 session target ipv4:10.102.XXX.YYY
 codec g711alaw
 fax rate 9600
 no vad
Zdravko did you ever get this resolved?
yes I removed the ATA and use Cisco 1751 router instead and works fine.
JDT69RR
I am having this issue. My PBX is CME. I have SIP service and below is the current config on the ATA.
