10-18-2010 10:06 AM - edited 03-16-2019 01:24 AM
I cannot get this fax complete to email, it cuts himself in half. I recieve this in FXO.The image of fax I can to see only half other part is cut.Anyone can helpme? Thanks
I have this IOS:
c2801-advipservicesk9-mz.124-24.T3.bin
This is my config
fax interface-type fax-mail
mta send server 10.1.1.1 port 25
mta send subject FAX NAE
mta send mail-from hostname fax.com
mta send mail-from username $s$
application
service onramp flash:app_faxmail_onramp.2.0.1.3.tcl
voice-port 0/1/0
input gain 4
timeouts call-disconnect 1
timeouts wait-release 2
timing hookflash-out 500
connection plar opx 3960
station-id number 5931
caller-id enable
dial-peer voice 13961 pots
service onramp
destination-pattern 5931
incoming called-number .
direct-inward-dial
port 0/1/0
dial-peer voice 13960 mmoip
service fax_on_vfc_onramp_app out-bound
destination-pattern 3960
information-type fax
session target mailto:faxtest@dominio.com
image encoding MH
10-25-2010 05:43 AM
Santiago,
With the fact that faxes are working to begin with but not completing, it do not think it is a signaling issue.
With T.37 faxes it buffers the fax page information, this then has to be converted to a TIFF video format and then finally converted to a 7 bit MIME mail atttachment coding. As a result, it uses large amounts of memory. We have found that the gateway routers need large amounts of memory and the IOMEM should be increased to around 10-15% of main system memory.
Said that, it may not definately be the cause of the faxing problems however you can try to increase the IOMEM to a larger amount to see if this does
resolve the issue.
By default the IOMEM is around 12-14 MB. You can add the following command -
memory-size iomem 10
This will boost 10% of your IOMEM. Once done, reload the router and try sending the fax again.
P.S. - Before making the changes, make sure that this router is not heavily utilized from memory perspective.
HTH.
Pratik
10-25-2010 09:50 AM
10-26-2010 02:02 AM
Santiago,
It seems that the current IOMEM is set to 10%. Go ahead and apply the command "memory-size iomem 15"
Get a scheduled outage window and apply the changes. This will allow you to test faxes and normal calls.
Thanks.
Pratik
10-25-2010 01:48 PM
I have seen this issue before. My fix was one of two things.
1. fix slips on the PRI with
network-clock-participate wic 1
network-clock-select 1 T1 0/1/0
2. Check IOS version for the newest version in the series.
10-26-2010 09:25 AM
This is an FXO, so there is no clocking to be of concern. Those commands won't work.
Checking memory is a good call as a previous person mentioned. Check that first. If the issue persists, note this:
The T37 TIFF writer is fairly sensitive to frame/line issues and has a hard time correcting if an issue in the page data transmission occurs. You'd need an audio capture of the entire failed fax to identify if this is occurring, though.
We improved sensitivity with 15.1(2)T though, as documented with:
CSCtf61563
T.37 - minor clock/frame slips may cause truncated pages in tiff image
Hence, it may make sense to run 15.1(2)T1 and observe for behavior. If you still see issues, you'll need to get an audio recording for a full fax that fails to investigate further, which can pose to be difficult if this is an intermittent issue.
