04-21-2016 02:49 PM - edited 03-18-2019 11:57 AM
I have a Cisco 2901 ISR running CUCME with the VIC-4FXS/DID for fax machine. Calls are coming in via T1 PRI. What configurations are needed to add a fax machine in one of the FXS port and get it working? I already have all the phones in the system working.I went through lots of documents, but I find them confusing for a noob like me. To the best of my understanding, I can only build the following configs.
voice service pots
fax rate disable
voice service voip
fax protocol none
voice-port 0/2/0
description Fax
station-id name fax
station-id number 7220
caller-id enable
end
conf t
dial-peer voice 7220 pots
descritpion Fax Machine
destination-pattern 7220
port 0/2/0
end
04-21-2016 04:22 PM
This is the Video Over IP community, might want to move this to the other collaboration, voice/video subjects area
04-24-2016 05:29 AM
It's a POTS to POTS fax (PRI -- FXS) so it should not require much fax related configuration under dial peer. For fax to work make sure there are no slips/errors in your PRI link (show controller T1 <port no.>).
04-24-2016 02:09 PM
I can get the fax number to ring, but after it rings for a while, it says "your call cannot be completed as dialed, please check the number and dial again"
Also, there are no slips and errors.
#show controllers t1 0/0/0
T1 0/0/0 is up.
Applique type is Channelized T1
Cablelength is long 0db
Description: ISDN-PRI
No alarms detected.
alarm-trigger is not set
Soaking time: 3, Clearance time: 10
AIS State:Clear LOS State:Clear LOF State:Clear
Version info FPGA Rev: 08121917, FPGA Type: PRK1
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
CRC Threshold is 320. Reported from firmware is 320.
Data in current interval (147 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Data in Interval 1:
Data in Interval 2:
Data in Interval 3:
Data in Interval 4:
Data in Interval 5:
Data in Interval 6:
Data in Interval 7:
Data in Interval 8:
Data in Interval 9:
Data in Interval 10:
Data in Interval 11:
Data in Interval 12:
Data in Interval 13:
Data in Interval 14:
Data in Interval 15:
Data in Interval 16:
Data in Interval 17:
Data in Interval 18:
Data in Interval 19:
Data in Interval 20:
Data in Interval 21:
Data in Interval 22:
Data in Interval 23:
Data in Interval 24:
Data in Interval 25:
Data in Interval 26:
Data in Interval 27:
Data in Interval 28:
Data in Interval 29:
Data in Interval 30:
Data in Interval 31:
Data in Interval 32:
Data in Interval 33:
Data in Interval 34:
Data in Interval 35:
Data in Interval 36:
Data in Interval 37:
Data in Interval 38:
Data in Interval 39:
Data in Interval 40:
Data in Interval 41:
Data in Interval 42:
Data in Interval 43:
Data in Interval 44:
Data in Interval 45:
Data in Interval 46:
Data in Interval 47:
Data in Interval 48:
Data in Interval 49:
Data in Interval 50:
Data in Interval 51:
Data in Interval 52:
Data in Interval 53:
Data in Interval 54:
Data in Interval 55:
Data in Interval 56:
Data in Interval 57:
Data in Interval 58:
Data in Interval 59:
Data in Interval 60:
Data in Interval 61:
Data in Interval 62:
Data in Interval 63:
Data in Interval 64:
Data in Interval 65:
Data in Interval 66:
Data in Interval 67:
Data in Interval 68:
Data in Interval 69:
Data in Interval 70:
Data in Interval 71:
Data in Interval 72:
Data in Interval 73:
Data in Interval 74:
Data in Interval 75:
Data in Interval 76:
Data in Interval 77:
Data in Interval 78:
Data in Interval 79:
Data in Interval 80:
Data in Interval 81:
Data in Interval 82:
Data in Interval 83:
Data in Interval 84:
Data in Interval 85:
Data in Interval 86:
Data in Interval 87:
Data in Interval 88:
Data in Interval 89:
Data in Interval 90:
Data in Interval 91:
Data in Interval 92:
Data in Interval 93:
Data in Interval 94:
Data in Interval 95:
Data in Interval 96:
Total Data (last 24 hours)
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
04-25-2016 04:52 AM
As per logs the issue seems to be that fax machine is not answering the call after 2 minutes and then call is disconnected from calling fax machine. May be there is issue with cable or machine. Could you connect an analog phone to fxs port and check if calls are working with analog phone? could you also configure "direct-inward-dial" in your inbound dial peer 50 and from voice-port remove "local-alerting" if you don't need it.
04-24-2016 03:53 PM
Try configure the below on your router. as there is not fax method configure out here. the ground rule of any fax to work that your normal should work with any issue before fax switch-over take you need to fix the call which is happening right now.
voice service voip
modem passthrough nse codec g711ulaw
fax protocol none
try looking your configuration or enable below debugs to check what causing this issue
+debug isdn q931
+debug voice ccapi inout
+debug vpm signal
++Debug voice vtsp all.
Br,
nadeem
04-24-2016 11:36 PM
04-25-2016 12:24 AM
Can you attached show run from your router (CME) also mention calling and called party which dialing from PSTN?
i am quite affirm its a config issue however, having said that normal call should work first then we can talk about fax.
Br,
nadeem
04-25-2016 01:45 AM
04-25-2016 02:23 AM
Here is the flaws, you have 4 digit extension configured and GW receiving 10 digit of DNIS however, there is Translation rule which is configured wrong that's why call
failed
Calling Party Number:6465981125'
Called Party Number:8163668499'
Present configuration
voice translation-rule 2
rule 2 /^123...\(....$\)/ /\1/
voice translation-profile 2
translate called 2
dial-peer voice 50 pots
description Incoming Dial Peer
translation-profile incoming 2
incoming called-number .%
port 0/0/0:23
dial-peer voice 300 pots
description Fax Machine
destination-pattern 8499
port 0/1/0
Need to be modify translation to make it work or make your 10 digit extension which seems to be bad idea
create of modify the existing translation rule
rule 2 /.*\(....\)/ /\1/
cc_api_call_setup_ind_common:
cisco-username=
----- ccCallInfo IE subfields -----
cisco-ani=6465981125
cisco-anitype=2
cisco-aniplan=1
cisco-anipi=0
cisco-anisi=0
dest=8163668499
cisco-desttype=2
cisco-destplan=1
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
005417: Apr 25 01:16:50.716: //-1/21E35F6E8174/CCAPI/cc_api_call_setup_ind_common:
Interface=0x2317BFAC, Call Info(
Calling Number=6465981125,(Calling Name=)(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
Called Number=8163668499(TON=National, NPI=ISDN),
Calling Translated=FALSE, Subscriber Type Str=RegularLine, FinalDestinationFlag=TRUE,
Incoming Dial-peer=50, Progress Indication=NULL(0), Calling IE Present=TRUE,
Source Trkgrp Route Label=, Target Trkgrp Route Label=, CLID Transparent=FALSE), Call Id=-1
005418: Apr 25 01:16:50.716: //-1/21E35F6E8174/CCAPI/ccCheckClipClir:
In: Calling Number=6465981125(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
005419: Apr 25 01:16:50.716: //-1/21E35F6E8174/CCAPI/ccCheckClipClir:
Out: Calling Number=6465981125(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed)
005420: Apr 25 01:16:50.716: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005421: Apr 25 01:16:50.716: :cc_get_feature_vsa malloc success
005422: Apr 25 01:16:50.716: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005423: Apr 25 01:16:50.716: cc_get_feature_vsa count is 1
005424: Apr 25 01:16:50.716: //-1/xxxxxxxxxxxx/CCAPI/cc_get_feature_vsa:
005425: Apr 25 01:16:50.716: :FEATURE_VSA attributes are: feature_name:0,feature_time:1072821256,feature_id:1645
005426: Apr 25 01:16:50.716: //5845/21E35F6E8174/CCAPI/cc_api_call_setup_ind_common:
Set Up Event Sent;
Call Info(Calling Number=6465981125(TON=National, NPI=ISDN, Screening=Not Screened, Presentation=Allowed),
Called Number=8163668499(TON=National, NPI=ISDN))
005427: Apr 25 01:16:50.720: //5845/21E35F6E8174/CCAPI/cc_process_call_setup_ind:
Event=0x22648EF0
005428: Apr 25 01:16:50.720: //-1/xxxxxxxxxxxx/CCAPI/cc_setupind_match_search:
Try with the demoted called number 8163668499
005429: Apr 25 01:16:50.720: //5845/21E35F6E8174/CCAPI/ccCallSetContext:
Context=0x3E004CD4
005430: Apr 25 01:16:50.720: //5845/21E35F6E8174/CCAPI/cc_process_call_setup_ind:
>>>>CCAPI handed cid 5845 with tag 50 to app "_ManagedAppProcess_Default"
005431: Apr 25 01:16:50.720: //5845/21E35F6E8174/CCAPI/ccCallProceeding:
005432: Apr 25 01:16:50.720: //5845/21E35F6E8174/CCAPI/ccCallSetupRequest:
Destination=, Calling IE Present=TRUE, Mode=0,
Outgoing Dial-peer=300, Params=0x3E007874, Progress Indication=NULL(0)
Br,
Nadeem Ahmed
04-25-2016 03:00 AM
Nadeem, I modified the translation rule 2 to :
But is it not doing the same thing as earlier :
rule 2 /^816...\(....$\)/ /\1/ (sorry that was not 123, I was changing some numbers so that exact numbers wont appear and changed this one too by mistake.)
i.e changing the 10 digit number starting with 816 to 4 digit extension? I still get that "your call cannot be completed as dialed, please check the number and dial again".
04-25-2016 09:41 AM
Is this a fax call you are testing ? can you please connect a analog on the port where FAX machine is connected?
Please re-collect the following debug (no need to collect in separate) enable these debugs in one go and make one test call
+debug isdn q931
+debug vpm signal
++ debug translation detail
Ps: Please make sure you connect a anlog phone where fax machine is connecte d then make test call. once through please mention calling and called party number along with logs
Br,
Nadeem Ahmed
