Federate between two IM&P Clusters
m.batts
Level 4
Level 4
Hi , I have two IM&P 10.5  clusters that I want to federate together
They are running different domains so I guess I can't use intercluster peers and need to use standard interdomain federation.
Just wanted to check I was on the right path and there wasn't another way
Jaime Valencia
That's correct, intercluster is far easier, but you need to be using the same domain on both for that to work.
java
if this helps, please rate
Jitender Bhandari
Like Jaime, said intercluster is between same domain, you will have to federate using one of the below explained process.
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cucm/im_presence/interdomain_federation/10_5_1/CUP0_BK_I07B7052_00_integration-guide-interdomain-federation-105/CUP0_BK_I07B7052_00_integration-guide-interdomain-federation-105_chapter_00.html
JB
