Somebody have use firmware MPP to device
7821,6921, 7911,7942,7962, sx20, VG224, VG320 and ATA187?
I saw that 7821 I can use starting on v3 but I don't find nothing about other devices.
I'd like register all device in the cloud.
Solved! Go to Solution.
Not every single device exists in the MPP flavor, none of the 79XX have an MPP version.
Go to the downloads site from cisco.com and search for the device model, if there is an MPP version available to download, it will be listed. If you don't see it, it doesn't exist.
You can also spend some time on google searching for: <device model> + MPP or 3PCC.
If you are referring to the Cisco cloud, might also want to spend some time reviewing the supported endpoints documentation, and / or reach out to a Cisco partner WITH voice/cloud specializations or a reputable consultant for assistance.
