11-05-2011 10:07 AM - edited 03-16-2019 07:53 AM
f
Good morning team,
I have a qauestion, I am upgrade a phone (SPA5044G) in CME (UC560-FXO-K9),
I configure the next.
tft-server flash:namefimware alias nuevofirmware
telephonyy-server
load 504 nuevofirmware
ephone 20 pd
resent
end
I think the upgrade working properly, but i dont know if any comand for see the firmware in use for the phone ?
Solved! Go to Solution.
11-05-2011 10:31 AM
Jorge,
You can run the command "show ephone phone-load"
That will show you the firmware version of each phone registered to CME based on Mac-address.
Please rate this post if it was helpful.
Luis Ramirez
11-05-2011 10:31 AM
Jorge,
Luis Ramirez
11-05-2011 10:47 AM
Luis,
Thanks for you help, excelent reply.
I also use show cdp entry * version in my switch, but it only use if the pone use cdp rigth, show ephone phone-load
can i use with other phone ?
regards
Jorge Cinco
11-05-2011 10:53 AM
Just like you said, show dsp neigbors detail will show you good ingormation about the phone, but the swith and the phone need to support CDP protocol.
The show ephone phone-load will show you the firmware for every registered phone.
Luis Ramirez
