Firmware update DX650
plavin001
Good Morning,
I have been trying to upload the .loads and .tgz files to my TFTP server.  The load file uploads fine and can be searched for, however, the .tgz looks as if it's uploading, but does not show up in a search.
The file is : pkg1.dx650.10-2-5-194.tgz
Thank you.
Aman Soi
this is a bug.
Cannot upload DX650 Firmware Through TFTP File Management
CSCus48862
Description
Symptom:
DX650 firmware installation fails with "File Not Found"
Conditions:
Firmware loaded using the zip option uploaded by using TFTP File Management
Workaround:
Use .cop file or manually upload to TFTP with TAC assistance
you need to use .cop.sgn file and upload using freeftpd s/w.
Use the option Software Upgrades---Install/Upgrade under OS administration Of CUCM.
regds,
aman
Aman Soi
this is a bug.
CSCus48862
Description
Symptom:
Conditions:
Workaround:
regds,
aman
Hi ,
thanks for rating.
Just for knowledge sharing, refer the release notes which says
Cisco DX650 devices labeled with TAN 68-5217-xx cannot be downgraded below version 10.2(2)
http://www.cisco.com/c/en/us/td/docs/voice_ip_comm/dx/series/rel-notes/1022/DX00_BK_R515C747_00_release-notes-dx-series-1022.html#DX00_RF_L5773E46_00
regds,
aman
plavin001
Thanks Aman!  That was driving me crazy.
