05-15-2012 05:27 AM - edited 03-16-2019 11:10 AM
Hi all ,
Equipment : CUCM System version: 7.1.5.32900-2
Hardware : Platform Type 7845H2
we have problems to upgrade the Phone 6941 Firmwareversion SCCP69xx.9-1-1-1-sr to SCCP69xx.9-2-2-6 .
the following problems occur:
The phone displays the new firmware, the phones are registered on the CUCM, calls come in and be displayed but the phone does not ring. The TFTP log shows
<CLID::NewCluster> <NID::xxxx> <LVL::Error> <MASK::0004>
05/10/2012 09:07:33.073 TFTP | CReqContext :: tftp [0xdf9cf80 ~ ~ 467 ~ 49 297 10.103.5.94] File [SEPxxxxx.cnf.xml] not found | <CLID::NewCluster> <NID :: 10.1. 31.31> <LVL::Error> <MASK::0004>
05/10/2012 09:07:34.981 TFTP | CReqContext :: tftp [0xdf9e340 ~ ~ 469 ~ 49 296 10.38.30.139] File [CTLSEPxxxxx.tlv] not found |
it looks as if the phones do not download the config files .
The problem only occurs with older phones Hardwrerevision. For phones with the latest hardware revision, everything works perfect.
has anyone a solution ?
thanks
Hajo
05-15-2012 10:13 AM
Hi Hajo,
Please go to System > Service Parameter > Select the Publisher server >
Select TFTP server > Click on Advanced button.
1.Set the Enable Caching of Constant and Bin Files at Startup
parameter to *False*.
2.Set the Enable Caching of Configuration Files parameter to *False*.
After that restart the TFTP service and the phone and see if the phone is
using the new firmware and working fine.
Tere.
If you find this post helpful, please rate!
05-15-2012 11:27 PM
Hi Tere ,
thank you for the hint. what are the impacts of this change ? I test it asap .
regards
hajo
05-16-2012 01:24 PM
Hi Hajo,
The parameters only determine whether the TFTP server will cache firmware binary files, locale files, and constant files such as ringlist.xml and config xml files at startup. There's no need to worry if you change this parameter.
Tere.
05-16-2012 12:25 AM
Another option is to try just restarting the TFTP process. This will rebuild all the configuration files for the phones. This shoud only take a few minutes. During this time, phones won't be able to boot, but booted, working phones will function normally.
GTG
05-08-2013 10:33 AM
Hi Hajo,
You can get resolved your issue with this step:
parameter to *False*. ??????
05-10-2013 02:19 AM
Hello all ,
I test the upgrade in our lab with 2 Cisco 6941 Phones and a WAN Simulator . In this test it looks like we hinting the knowing bug. If we upgrade from Software 9-1-1-1 to 9-2-2-6-Sr1 and use the wan simulator settings ( delay 80 ms 2 Mbit 1 % error ) the upgrade hung .The upgrade from 9-2-2-6-Sr1 to a higher software version works without any problems ( the same WAN settings ) . Now we use the local router as TFTP Server to upgrade all the phones to the software 9-2-2-6-ES1. This works fine.....
Thank you for all the usefull answers...
05-10-2013 02:40 AM
