10-31-2012 08:20 AM - edited 03-16-2019 01:57 PM
I have a Cisco 7940 phone running firmware P00305000101. I am unable to find a way to get it to connect to my tftp server, unlike the other phones with newer firmware.
I tried searching for support documents on this and it seems everything mentioning this FW has been removed from the site (not to suprising since its aparently over 12 years old). Does anyone know how to reset a phone's config that is running this firmware, and how to update the firmware installed?
10-31-2012 08:59 AM
The process of reseting the phone config is the same regardless of the firmware...
Can the phone see your dhcp server? You can do a factory reset on the phone but you need to ensure that the phone has access to a DHCP server with the correct tftp ip on it otherwise it will be stucked. You can also do a manual config on the phone giving it a static ip and tftp ip
Please rate all useful posts
"'Nature is too thin a screen, the glory of the omnipresent God bursts through it everywhere"-Ralph Waldo Emerson
10-31-2012 10:23 AM
When I reboot the phone and hold down the pound (#) button, I never get a prompt to reset the network config like the other phones do. It also doesn't respond to the "* + 6 + Settings" reboot command.
The other phones work fine with DHCP and have no trouble getting an IP, connecting to the tftp server and downloading firmware. Only this phone is having an issue.
