09-23-2010 08:43 AM - edited 03-16-2019 12:58 AM
I recently upgrade from CCM 4.2.3(sr4b) to CUCM 7.1.5. I have a model 7961 phone that would not take the firmware upgrade. I had to set the phone back to the default factory settings to get the phone to load up to a normal state at all. Right now the phone is on the network but not working. What follows is the firmware info from a working 7961 and the problem phone:
Working 7961
App Load ID jar41sccp.9-0-2ES2.sbn
Boot Load ID 7961G_64-02070631Amd64megRel.bin
Version SCCP41.9-0-2SR1S
Non-working 7961
Boot Load ID 7941G_02070629Amd32megREL.bin
I think I need to get the problem phone on the same firmware. The problem is I need to direct it to the firmware versions inbetween the two and step it up to the correct version. Does anyone know a firmware upgrade path that will get me close enough for the phone to take the version the other phones are running on my system?
jon
09-23-2010 08:44 AM
What I mean when I said that the phone was on the network but not working is that the phone loads, gets an IP
but does not register with my call manager.
09-23-2010 09:18 AM
Hi Jonathan,
You most likely need 8.5(2) as the interim/Mid-point firmware
Cheers!
Rob
09-24-2010 12:13 PM
Rob is correct, unless you want to load the unsigned 9-0-2 firmware on your call managers instead so you can upgrade directly to 9-0-2.
09-13-2011 04:55 AM
Hello, is there any documents that describes the upgrade path for ip phones..??
