01-08-2019 05:08 AM - edited 03-18-2019 12:34 PM
Dear Experts,
I have 2 E1.
Here his the diagram that i am using:
CUCM => H323 Gateway => E1=> sumsung OfficeServ PBX.
Diagram for incomming calls:
PSTN => E1=> H323 Gateway => E1=> sumsung OfficeServ PBX.
A caller call from the PSTN an internal phone, the internal phone ring. But when the user pick up the phone, we hear a busy tone and the error message below is show on the console.
%FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (0/1/1) to dsp_channel(1/0/2.
After look it at bugg: CSCvg29183, i tried Fuji-16.8.1, Denali-16.3.6 but I have the same problem.
Solved! Go to Solution.
01-08-2019 10:15 AM
This behavior (ring, then disconnect on pickup) is often a codec-mismatch issue. If the call is coming in G711alaw over the E1, and the router/CUCM are negotiating G711ulaw then a trans-compander is needed on the router in the form of a transcoder. The software MTPs in CUCM can also do the recompanding, but that would require that CUCM be aware of the need to do so, which I don't believe is happening in your current config.
If it won't mess up other things in your system, the simple answer would be to change your 'voice class codec 1' to prefer g711alaw over ulaw (and all of Cisco's phones support alaw as far as I know), and make sure that the H323 gateway configured in CUCM has MRG/MRGL access to CUCM's software MTP in the event it's asked to send that call to a G711ulaw-only device.
HTH. Let us know how it goes.
01-08-2019 04:07 PM
Hello ,
Maren and Jan, Thanks for your help.
After troublesooting this was due to the IPBX of the customer.
It's E1 was by default configure as switch type primary-net5 because of that i had configure the gateway's E1 to that same switch type.
I just change It to primary-qsig. and i also did the same thing on the gateway's E1.
It's working fine now.
Zanga
01-08-2019 05:14 AM
Hello Team:
Below is the sh run:
boot-start-marker
boot system flash bootflash:isr4300-universalk9.16.06.03.SPA.bin
boot-end-marker
vrf definition Mgmt-intf
address-family ipv4
exit-address-family
address-family ipv6
exit-address-family
card type e1 0 1
no aaa new-model
no ip domain lookup
subscriber templating
isdn switch-type primary-net5
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
fax protocol t38 version 0 ls-redundancy 0 hs-redundancy 0 fallback none
h323
no call service stop
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g711alaw
codec preference 3 g729r8
voice-card 0/1
no watchdog
license udi pid ISR4321/K9 sn FDO22432NBH
diagnostic bootup level minimal
redundancy
mode none
controller E1 0/1/0
framing no-crc4
clock source line primary
pri-group timeslots 1-31
description "connected to TELCO"
controller E1 0/1/1
framing no-crc4
description "connected to IPBX"
interface GigabitEthernet0/0/0
ip address
negotiation auto
interface GigabitEthernet0/0/1
no ip address
shutdown
negotiation auto
interface Service-Engine0/1/0
interface Serial0/1/0:15
no ip address
encapsulation hdlc
isdn protocol-emulate network
isdn incoming-voice voice
interface Serial0/1/1:15
no ip address
encapsulation hdlc
vrf forwarding Mgmt-intf
no ip address
shutdown
negotiation auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip tftp source-interface GigabitEthernet0
ip route
ip ssh version 2
control-plane
voice-port 0/1/0:15
bearer-cap Speech
voice-port 0/1/1:15
timing delay-connect 20
bearer-cap Speech
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
dial-peer voice 1 voip
destination-pattern [1500-1520]
session target ipv4:CUCM-IP
voice-class codec 1
dtmf-relay h245-alphanumeric
no vad
dial-peer voice 1000 pots
description "MOBILE CALLS"
preference 1
destination-pattern [045678].......$
port 0/1/0:15
forward-digits all
dial-peer voice 1001 pots
description "LANDLINES CALLS"
destination-pattern [23]T
port 0/1/0:15
forward-digits all
dial-peer voice 1002 pots
destination-pattern 245074[50-99]
incoming called-number .
port 0/1/0:15
forward-digits all
dial-peer voice 1010 pots
destination-pattern [1000-1400]
port 0/1/1:15
forward-digits all
dial-peer voice 1030 pots
destination-pattern [3000-3400]
port 0/1/1:15
forward-digits all
dial-peer voice 1020 pots
destination-pattern [2000-2400]
port 0/1/1:15
forward-digits all
dial-peer voice 1040 pots
destination-pattern [4000-4400]
port 0/1/1:15
forward-digits all
dial-peer voice 1050 pots
destination-pattern [5000-5400]
port 0/1/1:15
forward-digits all
dial-peer voice 1060 pots
destination-pattern [6000-6400]
port 0/1/1:15
forward-digits all
dial-peer voice 1070 pots
destination-pattern [7000-7400]
port 0/1/1:15
forward-digits all
dial-peer voice 100 voip
destination-pattern 5555
voice-class codec 1
no vad
01-08-2019 02:10 PM
This is an ISR router
So first make sure that you have DSP's on the NIM card
And under E1 config put the command: pri-group timeslots 1-31 voice-dsp
Jan
01-08-2019 10:15 AM
01-08-2019 04:07 PM
Hello ,
Zanga
02-17-2023 01:33 AM - edited 02-17-2023 01:34 AM
I had a similar problem with a Cisco 2911 with a DSP module and a BRI module VIC2-2BRI-NT/TE.
It happened that some calls were muted. The signaling worked but the audio didn't.
I changed the router and changed the DSP and changed the IOS but after a certain number of calls the problem reappeared and was temporarily solved by restarting the device. The first calls went through regularly and then randomly some were without audio and with this error message.
Feb 8 10:23:14.673: %FLEXDSPRM-3-TDM_CONNECT: failed to connect voice-port (0/0/1) to dsp_channel(0/0/0)
Feb 8 10:23:14.693: %ISDN-6-CONNECT: Interface BRI0/0/1:2 is now connected to 399099999 N/A
Feb 8 10:23:18.889: %ISDN-6-DISCONNECT: Interface BRI0/0/1:2 disconnected from 399099999 , call lasted 4 seconds
I resolved changing the VIC2-2BRI-NT/TE modules.
Gianrico Fichera
ITESYS SRL
