For CME new setup i want to dedicate DIDs
sweetsaif999
CME for 50+ employees with 2 E1 SIP TRUNKS  i want to know by using 10-12 DIDs i can implement this solution easily or not
1.one DID each Direct to 5 Managers
2.one DID each for 4 ATAs
3.one DID for 40 employees(is this possible in CME what should be used to enable this kind of scenario example: Auto Attendent or IVR or any other tool) if anybody can pass sample CME configuration for this small setup is highly appreciated.do i need to configure h323 on this gateway.
like this i have to implement in more 20 branches where the employees size is around 50,70,130,170,90..etc. in various locations already we are having CUCM 2 clusters version 7.1.5,H323 gateways with PSTN -SIP TRUNK and intercluster Trunk enable between this clusters. and we want to integate all this sites slowly.
Marwan ALshawi
so you will have one DID per magaer = 5 DIDs
and 4 DIDs for ATAs
not sure about employees what do you mean is it al of them reachable via one DID
if this is the case you can use B-ACD in CME or use CUE module with AA/IVR to enter the internal employee number
or send the call to receptionist for example and then the cal can be transferred as required
Hope this help
Thanks for your reply
1. I want this setup to provide call accounting for the incoming and outgoing calls for each extension of the groups.
2. To integrate this site with CUCM clusters  i need to configure h323 or sip trunk on both the sides(cucm and gateways)
3. Regarding employees DID how many local extension can be supported by a single DID(pilot Extension)
4.Any sample configuration for CME with this requirements is highly appreciated.
