08-08-2011 05:49 AM - last edited on 03-25-2019 08:08 PM by ciscomoderator
How to enable this feature for 1-2 subscribers CUCM 8.5?
I do not want to create another Route Pattern.
Solved! Go to Solution.
08-08-2011 06:55 AM
Unfortunately what you don't want to do is exactly what is required.
You enable this at route pattern level so there is no other way if you want this just for a few users.
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
08-08-2011 06:55 AM
java
08-08-2011 07:05 AM
thanks
I knew it
