477
Highlighted
Beginner
Forget security password during installation
        Dears'
                      We have Publisher and Subscriber . First , we instal Publisher .
                  Second , When we instal subscriber  ask for security  password
                 to communicate with Publisher  .
                     We forget the security password .
                   Is there any way to recover the security password ?
    Thanks ,
2 REPLIES 2
Highlighted
No but you can reset it.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/cucos/8_6_1/cucos/iptpch2.html#wp1053218
The process must be done on every node in the cluster and those nodes must be restarted after the passphrase is reset. This is a shared secret that protects the database replication. It is also used to encrypt your backup file. If you do not know the passphrase you will not be able to restore the backup! There are no workarounds or secret backdoors to this!
Please remember to rate helpful responses and identify helpful or correct answers.
Highlighted
  Dear '
       Thank you for assisting me
Best Regards,
